Question about Dynex 4-Port 10 Mbps Ethernet Hub
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE BLURAY. I CAN'T GET A CONNECTION. CAN ANYONE HELP?
  • Jeffrey Groves
    Jeffrey Groves Dec 29, 2010
    What is the make and model number of your router?
  • sherrie471 Dec 29, 2010
    I need a router ???
  • 536 Answers
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Posted on Dec 29, 2010
BUFFERING SLOW, THEN PICTURE COMES THEN DROPS.
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the streaming stick might be too far from your wireless router. Try to move the router closer to the Streaming Stick if possible. The best way to watch streaming video is with a wired ethernet connection with a Roku 3 or other wired device. Good Luck!
Jan 01, 2015 | Roku Streaming Stick HDMI Version
How to increase download speed on Roku 2
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the Roku might be too far from your wireless router. Try to move the router closer to the Roku if possible. The best way to watch streaming video is with a wired ethernet connection.
Dec 26, 2014 | Televison & Video
Cant connect to the wireless net work
You probably have a slow internet connection. It is recommended that you have a minimum 25/25 Mbps connection from your provider. If you do then the Roku might be too far from your wireless router. Try to move the router closer to the Roku if possible. The best way to watch streaming video is with a wired Ethernet connection with a Roku 2 or other wired device.
Nov 28, 2014 | Roku 2 XD Streaming Player 1080p (3050R
Acer intel 1 n450 won't connect to wifi
wired ethernet should be a Automatically detected when you plug in the cable. Does anyone else have the same problem. Try down powering the Ethernet switch if you have one in the network and wait 20 seconds and power it back up. Do the same for the Wi FI Router if it has one. .
Feb 19, 2018 | Computers & Internet
Hook up an ASUS N13U Router to a Speedstream 4100 Modem - ATT DSL
Both the modem and the router should have an ethernet cable connection. The modem probably has only one, the router may have more than one. Look for the one on the router labeled WAN or INTERNET or MODEM connection. Connect the two with a standard 8 pin RJ-45 connector cable.
Then, ordinarily, just reboot each. Turn off the router, reboot the modem, the turn on the router. It should connect automatically.
Sep 21, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
I have a sharp aquos blue ray BDHp24u, that says it is capable to get internet for netflix. What do I need to get a connection. I have a verizon wireless router. Do I need to hook up anything to the...
You would connect an ethernet cable between the bluray player and wireless router. If the wireless router is too far away you would need a Sharp PLC adaptor
http://www.electronicexpress.com/product?prod_id=13580
Jan 09, 2011 | Sharp AQUOS Blu-ray Disc Player
I just got this dynex 4 port ethernet hub and i have comcast wired internet . and i want to hook it up to my xbox 360 and my computer but , it wont let me . when i try to get xbox live it says network...
You need a router not a hub or a switch. with the help of the router you can share the comcast cable internet on multiple devices. A hub or a switch can not do this.
Get it replaced with a router. You can buy Linksys or Netgear router.
Rashish
Aug 17, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
What is the maximum speed
The speed of that router is 100 mbps (wired) and 54 mbps (wireless). If you have a 1 mbps line, that router is more than sufficient. Your speed will change simply because someone is using the internet connection. Downloading, uploading, surfing, chatting, listening to internet radio, etc. Make sure no one is on, then test it to see what speed you get. Go to www.speakeasy.net/speedtest and select the server nearest to you. It is a very good speed tester.
Good Luck!
Dec 05, 2008 | NetGear WGR614 Wireless Router
Dynex 4-Port 10 Mbps Ethernet Hub Logo
204 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
