Question about Uniden Cordless Phone
What do you check when the phone lists a message of "Check TEL Line"? The phone cord in plugged in so I'm not sure where to go from here. I have a model DECT1480
  • Uniden Master
  • 5,100 Answers
Usually this means that the phone isn't detecting a dial tone. For diagnostic purposes, I like an old corded phone.
First try a new telephone cable between the jack and the phone. Then try the old phone and see if you have a dial tone. If you have a dial tone with the old phone but not the cordless, then the Uniden needs service. These phones are not designed to be fixed by the user. If the phone is under warranty, send it in. (see page 28 of the manual www.uniden.com/pdf/DECT1480-3om.pdf )
If neither phone gets a dial tone, check at another jack if you have several to see if the jack is the problem or if it is a more global problem. If the problem is at one jack, you may want to open the jack and check for a loose wire. Some wall plates hold the wires with screws; others use a keystone jack with the wires pressed into slots using a "punch down tool". Keystone jacks do not need the insulator removed from the individual wires. For the screw connectors, you do need strip the individual wires. The punch down tool is available at many hardware stores in the electrical section (for wiring homes for ethernet and other services).
If you do not have a dial tone at another jack, find where your telephone service comes into your home. Open the panel and identify how the connection is set up. Some use RJ-11 jacks. In that case, plug in your test phone and see if there is a dial tone at that point. If there is no dial tone, contact your phone company for service. There is a break in the wires coming into your home. The phone company will fix this for free. (If the service doesn't use an RJ-11 jack, you need a special adapter to test at this point. Your phone company technicians will have this.)
If there is a dial tone at the incoming service, you have a inside wiring problem. Check any visible phone wiring for damage to the insulation. If the problem is with wiring inside a wall past the jack, you will need a professional to track the break. Your phone company will fix this for a fee.
I hope this helps.
Posted on Dec 29, 2010
Getting check tel line message on base unit. Checked all the plugs on handsets, but still get message.
It could be one or more of these:
- the cord that goes from the base unit to the phone company wall jack is faulty
- the cord that goes from the base unit to the phone company wall jack is not connected or is not plugged in to the base unit jack labelled 'line'
- the wall jack is not active (ie; does not have phone company dial tone)
Sep 04, 2017 | Lands Phones
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
Check TEL line
Is that what appears on the screen?
If so it means that it's not seeing the phone line.
1. Plug in a basic phone to make sure the line really is working.
2. Check the phone cord is connected to the correct socket (probably marked line)
3. If still no line change the cord and make sure that it suits the pin-out of your country. Most of the world uses pins 3 and 4 but the UK uses 2 and 5 on it's wacky BT flat plug. Israel uses this BT plug but uses pins 3 and 4 !!
Oct 27, 2013 | Uniden Cordless Phone
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
Message displays "check tel line". All
What you need to do first of all , put of the phone then disconnect it from the power supply allow he phone for about five minute ,then put it on again check the phone respond on your command if the problem remain same or solve.
Note if the problem remain then you will need to send me the name and the mode /serial number of the phone to guide you further.
Thanks.
Sep 06, 2011 | Panasonic Lands Phones
Message on handset reads - "Check TEL Line"
This generally indicates a phone line tha is dead. It may have timed out because a phone on the line has been left or knocked "off-hook". If so hangup the offending phone. In a short time the problem will self-correct. Beyond that, unplug ALL the phone appliences ( Fax,Computer, phones) Then, after waiting about 5min plug in 1 phone to see if it works. If that worked, re plug in the remaining items 1 at a time checking that the phone still works. If it quits, the last item you plugged in is likely causing the trouble.If the phone did not work, then go to the demarcation test box(ouside where the phone line comes in) open the portion which does NOT have the tamper proof screw. Unplug the short jumper wire and plug in a telephone. If the phone works there, the incoming phone service is ok, if it doesn't work call for service. If callers have complained tha you seem to pick up then immediately hang up, clean accumulated dust from jacks that are on outside walls particularly any near humidfiers tha may have caused the dust to become conductive. (a vacume cleaner should work) PS look for chewed cords (cats, dogs)
Dec 30, 2010 | Uniden Lands Phones
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
I bought a Uniden cordless phone, put the batteries in (it has 4 remote bases) and charged it for 20 hours as instructed. I tried calling it on my cell phone but I'm not getting s response. The display...
Double check that the telephone cord is firmly plugged into the back of the cordless phone base, the wall outlet, the outlet where the telephone modem is and at the L1/L2 jack on the back of the telephone modem. Your phone is not getting the dial tone line voltage from the telephone modem to the cordless base. There might be a short in the wiring. (It is unclear as to whether you are setting an old phone into this new base or swapping out and using another base with the old phone. Irregardless, the problem would seem to be not in the phone but ratther narrowed to the cord between phone modem and phone base. That is a very good reason to check how firmly the cord is plugged in.
Aug 27, 2017 | Lands Phones
Not sending fax
Plug a phone into that line and see what happens. Let me know what happens. Plug the phone into the line that goes into the fax machine. Make sure it works and is clear. No static or noise.
Apr 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Uniden Cordless Phone Logo
280 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
