Question about Jaguar MCE6605 Air Conditioner
Vax carpet cleaner
My vax carpet cleaner wont work the fuse is fine, what else could it be ?
    Sergeant:
    Champion:
  • 330 Answers
Use OHM meter to check the cable see if it is ok. smetimes the plug had problem. good luck
Posted on Jul 07, 2008
When i press trigger for water,It wont dispense water when hose is attached but i get a water flow when hose is placed over the side,ive checked for blockage in pipe ? Vax135u rapide
Vax135u rapide... UK: carpet cleaner, 4+ stars
Hello Jet Black,
Check the bottom of the clean water tank to make sure it is fully seated... and the hose connections...
Else you have a loose/broken fitting from your "trigger"
VAX Rapide 135U Carpet Washer Cleaner
Vax Rapide Spring Clean Carpet Cleaner 135U
Aug 06, 2016 | Heating & Cooling
My vax rapid carpet cleaner no suction filter is fine
If the vacuum is still functioning, the hose is most likely clogged. Disassemble the vax and unclog. Make sure you drain before disassembling. If possible do this outside.
May 16, 2016 | Filter Vacuums
My vax rapide w89 will not spray water from the bottom
Hi s_hall9800,
We bought a Vax Rapide Carpet Cleaner and were disappointed with it's performance as we couldn't see it spraying the cleaning soltion onto the carpet. I found there was no pump and gravity was all that put the solution on via a sparge pipe, controlled by a trigger-operated valve. So, all that happened was an intermittent sort-of dribbling. The cleaner picked -up quite well, though and we sprayed the carpet using a separate hand-held sprayer.
Nov 21, 2014 | W87-Rh-P Rapide Ultimate Clean Upright...
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Vax upright carpet cleaner
could be blpcked
Feb 18, 2012 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
Heating & Cooling Logo
519 people viewed this question
Top Jaguar Heating & Cooling Experts
Lawrence Oravetz
michael vanier
NOEL
NOEL
Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
