The laptop was turned off improperly and the power light is on but there is nothing oon the screen
  • 536 Answers
Try pressing and holding the power button down until the power light goes off.
Once it is off, then try to turn-on the laptop as usual.
If this does not work, remove the power cord and the battery from the laptop, and then press and hold the power button down for 30 seconds.
After the 30 seconds, release the button, install the battery and re-connect the power cord. Start the laptop as usual by pressing the power button briefly.
Posted on Dec 29, 2010
Black Screen
this is a power related issue. Try to remove the battery, remove any cd that may inside the cd drive, remove any usb or anything connected to the pc like a network cable. and remove the charger as well. Now press and hold the power button for about 2 to 3 minutes.This might have been caused by improper shutdown or power fluctuations and or if you slide your laptop on a bed or carpet, this builds up static electricity around the computer's motherboard and may prevent it from starting up properly. Then after pressing the power button for that long, replace the battery only and try to switch on the machine and observe. I hope this will solve your problem
Aug 23, 2013 | Computers & Internet
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
My toshiba l355d black screen all fans and lights are working
Monitor Toggle
Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Force Restart
Force Power Down
Hope this helps
Nov 03, 2012 | Toshiba Satellite L355D-S7901 Series...
Laptop is run and start but no display
Monitor Toggle
Force Restart
Force Power Down
Hope this helps
Oct 22, 2012 | Toshiba Satellite A500-ST5608 Laptop DC...
Son was playing a game on the compaq f700 presario. It locked up and my son shut it down improperly by holding down the power key. Now, when powered on, the computer power light comes on, the hdd spins...
Hi
i would try to press F8 on startup and hopefully it will take you to a few options of repair
its worth trying to use last good known configuraration
it may work
or system restore back a bit
hope you can see the screen when you try
good luck
Feb 19, 2011 | Computers & Internet
I cant turn on my camcorder but it wont turn oon at all ive tried everything
Is the power pack connected? make sure battery is charged (around 5 hrs) if nothing this means your camera has passed away, sad that as lots of that model failed like yours.
Jul 11, 2010 | Sony Handycam HDR-SR1 HD Camcorder
Abit kn9 sli, my problem is this, when i turn my pc on the fans spin for about one second then it all turns off. the power lights on the motherboard stay on but it wont power up at all. if i turn the power...
Are you sure the 4 pin connector is going in correctly? Some motherboards have an 8 pin socket, and the connector can be placed in improperly. The symptoms you describe indicate a dead short on the power line when plugged in.
Jun 20, 2010 | Abit KN9-SLI Motherboard
Clip won't restart -dead?
it sounds dead to me
is there a master reset or anything on there?
i dont have oone myself but i have similar things
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Power light comes on but nothing else happens
hi
when you power up ,turn the laptop around and listen closely underneathfor the sound of the hard drive ...no sound =goosed HD
Jan 10, 2008 | Dell Latitude CPX Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
