Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Will not finish is at spin and stoped,door will not open.has code 04
  • Bosch Master
  • 2,605 Answers
Welcome to fixya.
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely.
You haven`t mentioned if you`ve actually visually checked the pump...it is likely just that, a blocked pump.
Anyway, here`s the most likely way to remedy a E04 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, hopefully you won't get wet. ( maybe you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
3. Find a drill bit or small screwdriver that fits in the hole in the round door.
4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan. This will deal with the door lock issue but it likely isn`t unlocking due to the water in the tub )
**There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.**
6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, or a lock, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
Regards,
Macmarkus :)
Posted on Dec 29, 2010
What does code E13 mean?
Posted on Jul 09, 2011
Maytag 3000
Pump bad? Or something is wrong with the motor. Look up the default code in your manual
Oct 27, 2013 | Dryers
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Machine Stoped at the begining of spin cycle
The door switch or its actuator is not making contact. This is assuming that the other cycles work properly. Basically it thinks the door is open and it will not spin.
Jul 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Flashing E:04
Further on the solution provided on Oct. 28th.
The circular cover is on the front, below the door on the 3200UC. Use an unfolded large paper clip or in my case a large safety pin and push in where there is a small hole. Rotate the cover slightly and it opens. Once you get that open, there is a valve to unscrew. Be sure to have towels or sponges around as this will drain what ever water is left in the drum. Unscrew the cover only a little until water starts to leak out. Once it's drained, remove the valve cover completely. There is then another white plastic piece that you can gently pry out with a flat head screw driver. Once that's out, you'll be at the main drain. In my case there was an infant sock blocking the drain. I removed that and the machine works like a charm again.
Hope the details help a bit. Thanks for the original solution!
Oct 07, 2008 | Bosch WFMC 3200 Front Load Washer
Euro tech front load washing machine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, after load finished door did not automatically open.
How old is the washer?
Treat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
468 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
