Question about Desa International Reddy Heater® RHER60A Utility
Starts,runs 5 minutes and shuts down.How do i adjust.
  • Desa Interna... Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Dec 29, 2010
Why would my harley davidson 1998 dyna wide glide stop running after a short trip after being shut off for 20 minutes and restarted?
when it shuts down does it sputter first or is the shut down immediate without warning. sputtering is usually a condition of lack of fuel.any intake leak at the manifold especially at the head will cause "sneezing" out of the carb. Restart can be difficult and intermittent. A weak ignition module especially the adjustable kind can be unpredictable. a lot of the after markets are adjustable.A 1998 scooter tells me you have an Evo and being it's 16yrs old the likelihood of having a stock module is nil. check the plug where the module plugs to the ignition harness as well. Often times,because of it's age,these pins turn green or they either bend or they pull out just enough to break contact. I've also experience cracking of the wire insulation causing temporary short. shutting down the engine and difficult restarts.As with all jobs,check the simplest and obvious and don't start buying parts until you have checked all connections especially at the module where it meets the ignition harness.
Jul 19, 2014 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
We use the remote to turn the hunter fan on and during the night the fan shuts off by itself. Is it in the remote? What can we do?
There is two things it can be. It can be the fan motor getting hot causing it to shut down. it has a thermoprotector switch that shuts down the electric motor, to stop from burning up the fan motor.And there is also a adjustment to run the fan for 2 minute and shut it down, pause 2 minute and start back up. there are 4 to 5 settings to chose from. anyway i hope this is helpfull to you. and ps you can clean the motor with air hose blow it both ways to loosen all the dust. later sawdust46
Aug 12, 2009 | Hunter 52" Ceiling Fan With Light And...
2001 Lincoln LS Cruise Control stopped working
could be the module behind the airbag
Jun 26, 2009 | 2001 Lincoln LS
Starts and runs 3-5 seconds and shuts down
Sounds like your security system is shutting the car down. You should be able to leave the key on for 15 minutes and it will reset itself. Make sure you are using factory keys, and they are in good condition.
May 28, 2009 | 2002 Pontiac Grand Prix
TV does not start
There is problem in your Display. It does not run when it becomes hot.
Sep 27, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Desa International Reddy Heater® RHER60A Utility Logo
176 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
