Question about Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit
I have a duo fast CN 350 nailer and it works ok but it don't seem to let the driver blade to come up high enough to get on nail head
  • 2,100 Answers
You will need to pull the top off to get to it to check it out, If the drive pin is bolted on, make sure the bolt didn't loosen up, most are one piece, welded on, If you don't find anything in there preventing it from coming up, I would grind off the tip, nice and square and flat, then put it back together. I have a feeling you will find a piece of white plastic holding the piston down, part of the head there, It will need to be replaced. Check it out, hope this helps.
Posted on Dec 29, 2010
What degree nails to use?
Your gun uses 22 degree round head plastic strip nails. Most likely nail that is easy to find in stores is 21 degree nails for Hitachi , Duo Fast and others. Both work ok.
Apr 03, 2013 | Porter Cable Cable No. FR350A Rnd Head...
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My Duo-Fast Strip nailer has the driver blade jammed in the nose of the tool, cannot budge it?
Possibly a piece of nail,,use a small flat tip punch and small hammer and see if you can dislodge drive,,E Z does it
Feb 05, 2013 | Air Tools & Compressors
Repair duo fast nail gun
Duo-Fat is now owned by ITW which also owns Paslode. The DF350S is basically the same thing as the F-350S Paslode. Go to Duo-Fast's website to locate a servicing dealer nearest to you.
http://www.itwindfast.com/buy.cfm
Feb 16, 2012 | Duo Fast DuoFast DF350S 20? Round Head...
What degree nails should be used for a duo fast Cn 350 B nail gun?
The CN350 uses a 20 degree, full round head, plastic collated nails.
Jul 21, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have got a second hand Duo-Fast CN350B Nail Gun. It is new to me, and I dont have a operating manual for it. I have heard they accept multipule guage nails, is this true? Also can the nail driving depth...
They use 20 degree, full round head, plastic coalated nails. You can shoot nails ranging in guage from .099 to .131 and I believe from 2 3/8" to 3 1/4" length. It is a heavy but well built and powerful tool. It's not made anymore because Duo-Fast has long been sold to ITW which also owns Paslode. The owner of Duo-Fast (third generation, family owned) got very ill with cancer and ended up passing away quite a few years back. I worked as a sales rep for Duo-Fast in the early 1990s. I can not find an owners manual link for you. They don't have an adjustable depth but they do have a flush adapter. Here is a link to a parts diagram. The flush adapter is part number CN-133 and is held on with a screw.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/duofast/CN-350B
Jul 17, 2011 | Tools & Hardware - Others
Nail gun will not fire the nail. Compressor works fine. Hammer doesn't retract enough to hit nail? Cause, solution?
could be a jammed nail in the magazine nose area, bent driver blade or problem with the o ring being worn.
Jun 06, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
I have a duo-fast n350 ant it sets the nail to deep . any adjustment
Three methods to adjust how deep nail will set. On nose of gun is fine adjustment, move contact claw by backing off screw and moving up/down. Replacing the lower bumper with new part will prevent driver from driving too deep into work (new bumper is more firm and probably thicker). Finally, adjust piston on driver blade by turning then re-apply lock tite (adjust piston head closer to work). Good luck
Feb 20, 2011 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
I have a duo fast cn350b that misfires, the piston seems not to retract back into the chamber
I have the CN350 - not sure how it and the 350B differ.
There are several possibilities that I've experienced.
Nails other than Duofast. Causes a jam that does not allow the driver to return.
Not enough oil.
Not enough air.
Worn O rings.
Sep 09, 2010 | Duo Fast Duofast Cn350 Cn350b Sh Nailer O...
Duo Fast Duofast Cn350 Cn350b Sh Nailer O Ring Rebuild Kit Logo
438 people viewed this question
Top Duo Fast Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
yoopertech
Are you a Duo Fast Air Tool and Compressor Expert? Answer questions, earn points and help others
