Question about Kenmore 400 6943 Dryer
All of a sudden the dryer is not running at all. We are going to have an electrician come out but would there be any other reason. We bought it just over a year ago but have only used it about 6 months. so the warranty is expired.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
My beko dryer keeps tripping my electric box
We had similar problem with a different type dryer. Turned out to be a weak / older / bad breaker in the electrical panel. Every so often it would just trip the breaker for no reason.
The owner thought it was the dryer itself - and bought a new one - but problem remained.
In our case - solved by electrician putting in a new breaker in the panel for the dryer.
Could still be your dryer though, in your case.
Suggest:
- make sure dryer vent is not plugged by lint or other stuff.
[ When running, check that you've got good flow of hot air coming out the outside vent. If NO, could be a plugged up vent. We've had that too before. Disassemble, clear out vent tubes, check for plugged up screens, on the outside too, there is sometimes a screen in the outlet - it could get plugged. The screen is important - to keep out leaves & animals & stuff - but typically gets plugged up. Then dryer overheats and shuts itself off or trips the breaker. Also - you'll find that it takes longer to dry anything if the flow of air going out is restricted.]
Oct 25, 2013 | Dryers
Stops while running
i had this problem before , there is something down in the circuit board , its shorting as the reason it suddenly stops , get an electrician to fix the problem , if the board is to critical to be fixed then you need to get a replacement , call up the manufacturer or any store room close by , they ll replace the circuit board for you
hope this helps :)
Jan 25, 2013 | Exercise & Fitness
Old dryer turns but does not heat, so bought a new one the same thing happens, can it be the electric plug?
A plug is easy to change, You can do it your self, Just make shure you turn your breaker off, Before you remove the old plug,Follow the wires on the old plug, End connect them to the same terminals on the new plug.Allso you can Write it down where they go,Before you disconect the wires from the old plug, Try the cheap route first, End that is to replace the old plug,
Oct 18, 2012 | GE GTDP490EDWS 7.0 cu. ft. duradrum...
Just bought a dryer, can i put a 120v plug on it? My plugs are 120v.
No. Electric dryers run on 220vac
If you do not have a 220vac plug at the wall, you will neede an electrician to install one for you.
Hope this helps...
Aug 27, 2011 | Maytag Dryers
Kenmore series 80 electric clothes dryer suddenly, the dryer won't start. hold the button in and nothing happens except the timer sounds like it is running. release the button, nothing.
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 30, 2011 | Dryers
Dryer was running. All the sudden stopped, I smelled a burning odor. Will not start.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 30, 2010 | Maytag HYE3657A Electric Dryer
Dryer sudden not working
heatman101
Dec 26, 2010 | Dryers
My dryer quit working all of a sudden.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 13, 2010 | Maytag Dryers
Replaced a 4 prong plug with a 3 on a Gallery
the reason for the four prongs is the same reason most electric ranges have them it is higher amperage and it is a heavier duty machine I suggest you put original plug back on and purchase the proper wiring and receptacle for it as well before you have a fire I strongly suggest you contact an electrician
Dec 17, 2009 | Dryers
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Kenmore 400 6943 Dryer Logo
162 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
