Question about Canon ImageCLASS D1120 All-In-One Laser Printer
I can't print double sided copies from a mac onto a canon imageclass D1120 printer. I know the rinter has duplex capabilities. downloaded and installed the driver i was sure was correct. When i go to print, however, the 2-sided option is unclickable.
  • 10,421 Answers
I tuyrned off duplex and keeps pulling paper back in to duplex
Be sure the setting on the computer are correct, they can override the settings on the printer.
Apr 03, 2014 | Canon imageCLASS D1120 Copier
Cannot print in Duplex canon mf8350cdn
Go To Below official Canon Printer Page For Your problem, http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Mar 07, 2014 | Canon MF8350Cdn AllInOne Laser Printer
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Feb 05, 2011 | Canon PIXMA iP90v Printer
How to get a Canon MG5220 printer to print 2-sided copies
If you have a Canon MG5220 you certainly can print two-sided. I have one and I print two=sided pages. When you bring up your print menu underneath "Orientation" is a small window that likely says "layout". Click that window and you will have various options to choose from; color matching, paper handling, cover page, quality media color options. borderless printing and duplex printing & margin. Choose Duplex & Margin. Once you've clicked that you'll see a check box for duplex printing, click that box. You have other options for for reduced or normal printing (your choice) and then if you're stapling there's options for the side you'd prefer but the point is once you've checked off that box for duplex printing you're set to go.
Feb 05, 2011 | Canon imageCLASS MF7480 Laser Printer
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Sep 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageClass MF6530
This is a "monochome printer" ie B/W, double sided is called duplex select this option on printer driver on pc
Dec 01, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
No printing on Mac OS 10.5.1
Check under the Apple site for this issue. I use Leopard and can copy and print with this machine. I have not tried the fax, however, I assume  it will work. The scanner does NOT work with Apple...at least yet...I am not sure if it is Apple or Canon or both who are at issue for this. As per the post below, the duplex works just fine for me. You may want to consider the possibility of removing the current drivers and reload the one's currently posted by Canon.
Duplex Printing
Apr. 19, 2007
Archon Fung
I figured out how to make duplex printing on the MF4150 work! Canon Tech support says that duplex printing is not supported, but they are mistaken.
Here is what you need to do:
1. go to the Canon site and download the latest UFRII driver (v1.5) and install it
2. in the application, go to page setup and select "Format For:" MF4100 Series [this was what I did not realize]
3. then, when you go to print, select the finishing tab, and then select 2-sided printing.
If you skip step 2, and you application defaults to "format for any printer," the 2-sided option will be greyed out. Other printer drivers do not require this, but the Canon driver does.
Nov 26, 2007 | Canon imageCLASS MF4150 All-In-One Laser...
Canon ImageCLASS D1120 All-In-One Laser Printer Logo
117 people viewed this question
old marine
old marine
