I have a 3 band
Dear Audio expert(s)at FixYa, I have a 3 band Radio It's a PR -D3l It's sold and branded as a digitor by sangean and I bought mine through ****-Smith Electronics in Australia a few years ago. It has FM 87.5-108 MhZ, MW 522 -1710kHz and LW 144-279 kHz. I've been away for a short trip, returned to find the detail readout has changed. It's now displaying a changed FM range now 76.0 up to 108mH, BUT it processes no signal below about 100MhZ. Similarly the LW option doesn't appear at all and worst of all the MW range now cuts of at 1620, it no longer offers frequencies above this. Trying to find a web site for this model (not listed on www.singeing.com). This appears to be a software problem in the tuning chip as it works ok on those frequencies it now chooses to receive, but with those weird changes neither ordered nor wanted. Please assist. Signed Mark Newstead mark@mediamark.com.au
  • Mark Newstead Jul 07, 2008
    Thank you Ginko
    I have already disconnected both sources of power, but it does not reset to manufacturer's specifications.So what else might I try?
    Have tried removing all sources of power to "reset" to original specifications. No luck.
    Sergeant:
    Champion:
  • 230 Answers
Try the hard reset method ,that is, remove the battery and then insert the battery and switch the radio on ,it will help you.Otherwise try to tune the radio to required frequency by changing in the settings and try...
Posted on Jul 07, 2008
    Master:
  • 788 Answers
Use a paper clip or something similar to press the little reset button that should be located on the bottom of the radio. This will reset the microporcessor and get the radio working again.
The Digitor is the same as the PR-D3L from Sangean and the manual can be found here: http://www.sangean.nl/English/Products/pict.php?type=manual&file=dr_PR-D3_manual.pdf
    Scholar:
  • 135 Answers
Hello sir,,
u can download radio software from here
http://digilander.libero.it/i2phd/
http://software.hamradioindia.com/
fixed by fixya
thank u
    Master:
  • 638 Answers
Try reset by removing batteries n reinserting . if that does not help let me know so that we try somthing else.
  • 1,512 Answers
Hi mark774
First trick is to power it right down, remove batteries, to get a reset
If it is still faulty, then it will need some service work done. It may be also a synthesiser fault, but either way, **** Smith do have a repair service. They are probably the best to provide service on the product. I would call them tomorrow first and enquire about repairs.
regards
robotek
  • 19,396 Answers
Try first removing batteries, and or unplugging power to reset it
How do I delete a station?
Just "insert" another station into the spot.
Your tuner does not like "blank spots: in the station line-up.
Mar 07, 2015 | Sangean PR-D9W Radio Tuner
Why did the ac power quit working on my pr-d7? the dc still works fine.
there is a diode D301 must be opened, replace it should be ok, but have to check your AC adaptor in advance.
Nov 17, 2014 | Sangean PR-D7 Digital Rechargeable AM/FM...
No sound.
Read the manual. The radio may have been set to some defaults, although the time was not correct. When you started setting the time, it is possible that you should have run through the whole setup. For example some radios have different ranges for the FM bands: there is a Japanese band that starts at 76 MHZ, and ends at 108 MHz; there is the standard FM band from 88 MHz to 108 MHz; and a school band (I can't remember its range).
For AM the gap between neighboring positions may be set at 9 kHz or 10 kHz depending on the location (region or continent).
I suggest you get the manual and see if there is an initial setup procedure, then follow it.
Dec 27, 2013 | Sangean WR-2 AM/FM Radio
Sangean ATS-909X Volume control has failed (no longer trims volume). A little pressure on the control will sometimes restore its function. Sounds like a bad solder joint or a cracked board. Any th
A similar problem with SANGEAN ATS-909x I have too.
When you touch the volume control ever hear the full volume.
Tap volume control side, the sound is normal.
Suppose a poor connection on the control volume.
Correction here in Slovakia is not guaranteed.
Receiver has a serial No: 0C000451 is under warranty, purchased through E-Bay from Taiwan, made 1/2011 and purchased in 2012.
It seems that I remains only a decoration.
Milan
Translation by GOOGLE
May 11, 2012 | Sangean ATS-909X Professional Multi-Band...
Sangean PR-D3L AM-FM Radio RF gain intermittantly dropping. Would like circiut Diagram
The most common cause is a dirty rf controller, buy some electronic contact cleaner and take the unit apart and spray the compound into the pod and rotate control back and forth, repeat two or three times for maxium benifit.
Mar 02, 2012 | Sangean Audio Players & Recorders
I HAVE A PR-D3L, CAN I SET THE CLOCK TO 12 HOUR MODE? IF SO, HOW DO I GO ABOUT IT? THANKS....JOHN.
  • If you have any comments you can feel free to leave them here.\
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 18, 2011 | Sangean ATS 505 AM/FM/SW Radio
Sangean PR-D3L - How do I change between 12 and 24
Archer, I have read the entire PR-3DL manual and there appears no mention of a 12/24 hr setting, unlike certain other Sangean radios. The instructions for setting the alarm do not mention 'a.m.' or 'p.m.' .
Apparently, the clock is a 24:XX:XX display only.
Apr 05, 2010 | Sangean ATS 505 AM/FM/SW Radio
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Digital Radio Digitor by Sangean PR-D3L The LCD display has slowly been failing and is now 95%failed. Is there a spare part or other magical solution available
I have fixed the display on a Sangean PR-D3L that had faded to less than 30%. It was a bit involved and required pulling the radio apart and desoldering a metal sheild off the back of the display board to reveal the "zebra strip" connector for the display. I used a bit of heat and pressure on the connector strip where it contacts the circuit board - presto 100% display. Don't know how long it will last tho'.
Oct 08, 2008 | Audio Players & Recorders
261 people viewed this question
 Grubhead
Grubhead
