Question about Sony ICF-SW100S Radio
My Sony icf-sw100 radio has a problem with the battery hinge which will not close because the teeth of the case has worn. Can anyone solve the problem?
  • 10,594 Answers
There are two parts involve for that problem, its either battery lid that slides up and locks and other is casing where this lid teeth go to lock.
Part numbers of both parts are appended below..
390984101 .. LID, BATTERY CASE
X33685342 .. CABINET FRONT MAIN ASSY
Click above links to get price info, both are available in partstore.com
Hope these info will help you.
Thanks.
Posted on Dec 29, 2010
Unfortunately, this is the most common problem with this FANTASTIC receiver. The SW100 is without a doubt the coolest little radio on the planet.
I use a rubber band. Inelegant, but effective.
Posted on Mar 30, 2011
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
How do I set the. Time
With the radio off, press and hold the ENTER (time set) Key DOWN. On the right side, there are 4 buttons with arrows on them. The inside ones set the timezone that you are in, the outside two will set the time. I just checked this on my ICF-SW100 and it works for me.
Mar 04, 2015 | Sony Icf-sw100 World Shortwave Receiver...
Power transformer if change from 50 hz to 60 clock
Is that a question or a statement?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-ICF-C212-Clock-Radios-manual/id/267ag023/t/2/
Considering a 9VDC battery keeps the clock alive when power is disconnected, I would guess the clock time is independent of line current frequency. Does anyone actually use motorized clock works anymore?
Feb 19, 2011 | Sony ICF-C212 Clock Radio
When I tune in to a station in the radio (Sony ICF-SW7600) plays for 5 minutes then the volume disappears. The display still shows that the radio is tuned to the station but there is no sound
Hi, I have a suggestion that I hope helps here.
Let me give you some theory to think with.
Alkaline batteries do not act like conventional batteries do. When they are starting to fail the initially
give you high voltage but the power goes down rapidly. In other words, the voltage spikes and dies.
If you have mixed different batteries which are worn un-uniformly, or mixed battery types. i.e. Alkaline with non-alkaline then you could have strange characteristic in your radio. In your radio, I would test with a fresh set of batteries.
If you have the AC power adapter for your radio, I would try that as well, to see if the same thing occurs.
If it is not the battery issue, then it is the circuit board inside the radio. The parts on these circuit board were designed to be inserted with machines and are often too small to be put in by conventional repair technicians. Sony will have the components to repair if necessary.
Let me know how this goes for you.
Hope I've helped
Best Regards,
Mark
Jan 04, 2011 | Sony ICF-SW7600 AM/FM/SW Radio
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Just need a replacement telescopic aerial for my ICF SW100. Thanks!
There are many types available in the market - now being scare - but you can suit one with the same mount and size.
Some of the earlier models of cordless telephones have antennaes that can suit yourr requirement. Also check for old model radios to swap if you find there are no choices in the market.
If the old one is damaged or broken then you can mend it with mild gas welding.
Sep 17, 2010 | Sony ICF-SW100S Radio
Need replacement antenna for ICF-SW55 radio
dear Sir, I need the battery compartmenr lid and tha antenne for sony icf sw 55. I hope you could help me with that..Waiting for your instructions..best regards.. tuncay bayer . bursa - turkey arnildabay@hotmail.com
Nov 18, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
My sony world radio icf-sw100 wont turn on and i just put new batteries in it
Chances are the metalic "dome" under each button in question has rotated slightly out of position. This happened with the Sync button on my post-1997 SW100. Sunddenly no Sync function and nothing about Sync on the display. The problem is easily remedied if you're into radios. literally. (A friend fixed mine.) I know several individuals who might be willing to repair your unit. E-mail me for names? paul-diehl[at character]uiowa.edu
WARNING: VERGE OF RANT
Whatever your do, DO NOT SEND YOUR UNIT TO THE SONY REPAIR CENTER IN LAREDO. I sent mine in for the Sync repair and had it returned unrepaired, with "corrosion" given as the reason. I then had an electrical engineer take a look and he correctly diagnosed the problem in 90 seconds. Took him another 30 minutes to complete the repair, which required no new parts or soldering. By the way, he found NO CORROSON WHATSOEVER anywhere in the receiver. And by the way number two, SONY LAREDO returned my receiver with major dmagage to the chassis. After three frustrating months, I was finally able to get LAREDO to replace the part of chassis they'd broken. (They 'd counted on me not taking before and after photos.) Totally incompetent, totally unresponsive, totally dishonest (they said they'd ordered a new circuit board from Japan when they hadn't), just north of outright fraud. AVOID LAREDO AT ALL COSTS.
Dec 13, 2008 | Audio Players & Recorders
Sony ICF-C212 Clock Time Problem
that clock use LM8560 IC. if u live in a country with 50hz, u must close the jw11 (this make a jump betwen those pins 15 and 26). that enable the 50hz. left it open, when is 60hz.
Mar 21, 2008 | Sony ICF-C212 Clock Radio
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-SW100S Radio Logo
816 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
