HP dv6700 I have a HP dv6700 and I cannot get the disk drive to stay closed. If you close it, it will stay closed for about 5 seconds. After that you hear a funny noise and the drive opens on its own. Other than that, to my knowledge (which isn't much) everything else is fine.
    Genius:
  • 2,028 Answers
This is a problem with the relay switch in the drive that opens the slide. Unfortunately, you will have to replace the drive in order to fix the problem.
Posted on Jul 07, 2008
Cd rom drive door will not stay closed. i close it and then seconds later its back open again.
There's a little piece of plastic or metal that's connected to a sprin which clicks into place when you close the dvd drive and keeps it closed. Either the spring or the plastics is stuck or broken. They're very easy to replace and used ones don't cost much
Jan 15, 2011 | HP Pavilion G60-235DX notebook
HP IQ770 TouchSmart doesn't load up or stay on
Step 1: Disabling Automatically restart option to view error messages
1. You can prevent the computer from restarting by turning off the Automatically Restart option:
2. Click Start .
3. Right-click Computer , and click Properties
4. Click Advanced system settings .
5. Click the Advanced tab and select Settings in the Startup and Recovery section.
6. Remove the check mark next to Automatically restart under System Failure .
7. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
8. Restart the computer.
Check if it happens again
If it happens again do a hard drive scan(FULL)
Download the latest BIOS update from hp.com
Step 2: Reinstall Microsoft SATA disk driver solution
1. HP Vista computers that use the Microsoft SATA disk driver do not experience automatic restarts. If you updated your Windows XP computer to a Windows Vista capable computer using an HP upgrade solution, this Microsoft SATA disk driver is available to reinstall.
2. To reinstall the Microsoft SATA disk driver, follow the instructions below.
3. Click Start on the taskbar.
4. Click All Programs , PC Help & Support , and then select Recovery Manager to open the Recovery Manager window.
5. If prompted, click Continue .
6. Click Next to continue.
7. The next window asks if you want to perform a program recovery. Select No , and then click Next .
8. The next window asks if you want to perform a driver recovery. Select Yes , and then click Next .
9. Click Next again to continue.
10. Select Standard Dual Channel PCI IDE Controller from the list of drivers, and then click Next . The reinstallation process takes a few seconds.
11.Click Finish to restart your computer.
Feb 02, 2010 | HP TouchSmart IQ770 PC Desktop
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
Hp dv6700 laptop wont turn on power light comes on for 2 seconds
No its not a virus, your power led on *********** board is not receiving power, go and see a technician close to you
Sep 09, 2009 | Computers & Internet
Dvd drive will not start up or play dics
You should try it with a different disk. It sounds like that one you are using is scratched or the disk was not closed correctly when it was burned.
Jul 24, 2009 | HP Pavilion dv9000z Notebook
My Hp Pavilion dv6700 laptop will not start properly. I was in the process of installing a program, and the screen forze. I restarted the computer by holding down the power button, and I tried to reinstall...
Hi there.
Seeing as the laptop is only 5 months old it is still covered by the manufacturers warranty, the clicking sound you can hear is the hard drive failing, the hard drive is hardware and IS covered by the warranty.
Send it back to HP it won't cost you anything to have it repaired.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | HP Pavilion dv6000z Notebook
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
Disk tray won't stay closed
i have same problem with mine, if i close the tray quickly by hand after it re-opens,it usually starts reading the disc
Jun 14, 2008 | Microsoft Xbox 360 Console
DISK DRIVE PROBLEM
Sounds like it is not reading the disk, make sure it is clean. Can you hear it trying to spin?
I hope you didn't push too ******* the door, you can make it jump a tooth on the loading gear making it go out of time. Check here for more solutions http://fix-your-xbox-360.blogspot.com/
Mar 19, 2008 | Microsoft Xbox 360 Console
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
