Question about LaCie Hard Disk 750GB with Hi-Speed USB2.0 750 GB USB 2.0 Hard Drive
I have a Hi-Speed USB 2.0 750 GB hard drive. I cannot get it to open from the desktop, start, or from the program files. There was no installation CD that came with the device - only a "one click" installation wizard. I have tried to remove and then reinstall the software, but to no avail. I have checked the partition and it says "Disk 1 LaCie (F) healthy. Also the Hitachi disk drive appears to be there and the program files are in my C drive. I am running Widnows XP, SP3. Any suggestions?
  • hourston Dec 29, 2010
    Hi 7 sleven. Thanks again for your reply. I did uninstall the driver and reinstalled. Did not work. To answer your questions: 1. Yes, the HDD is used only for backup. 2. The software is what came with the LaCie device. It is called LaCie 1 Click Backup Software. 3. Yes, I can save a text file using Notepad and recover it from the external Hard Drive. 4. The backup files are in many formats because they appear on the HDD the same way as they are stored in the C Drive, for instance, word files, jpegs, etc. Thanks. Hourston
    Sergeant:
  • 320 Answers
Hi hourston,
Not sure what you mean by "remove" but this is what I would try if it were me.
I would disconnect the drive from the computer. Go to the Device Manager (start > right click "My Computer" > click on Device Manager > click the + in front of Disk Drives. When you find the drive, uninstall the drivers. Shut your computer completely off. Boot the pc back up, and shut it down once again. Plug the HDD back in and reboot. It should be plug and play and reinstall.
Just checked Microsoft's website, says it is Windows compatible with no action required (Plug and Play)
Hope that helps...
Posted on Dec 29, 2010
  • 3 more comments
    Hi 7sleven,
    Thanks - I think the question I asked was phrased incorrectly.
    The hard drive can be opened to view the contents, the problem is that when you click on the back-up icon, nothing happens and the drive will not perform a back-up. No activity registers on the task manager when I click the back up icon, but I can look at what is currently on the drive. Will uninstalling the drivers fix this problem?
    Thanks!
  • Joseph Moore
    Joseph Moore Dec 29, 2010
    Hi Hourston,
    Uninstalling and reinstalling the driver will not hurt, and it may indeed solve your problem. If that does not work, if you can answer some more questions I have,maybe I can help more.
    1. Is this HDD used only for backups?
    2. What backup software are you using?
    3. Can you save a simple .txt file to the HDD and reload it?
    4. Do you happen to know what format the backup files are in? If you can see the files, what are the 3 letters after the file name, ie somefile.???
  • Joseph Moore
    Joseph Moore Dec 30, 2010
    Okay, so your backup program does not compress the file and store it, it just stores the file in the same format that the original programs save the file information in. Can you you use one of the programs, ie. Microsoft Office, Excel, Adobe Photoshop, to open any of the saved files by using the open file command and pointing it to the HHD that is used for backing up the files?
  • hourston Dec 30, 2010
    Hi 7 sleven
    Yes, I can do that.
    hourston
  • Joseph Moore
    Hi Hourston,
    Okay, we should have you up and running in no time. From what you have told me, there is nothing wrong with the HDD, is is working just as it should, this is good. Now what you need to do is open your Control Panel, then open Add/Remove Applications, find your LaCie 1 click backup software, and uninstall it. Next you need to download CCleaner from Piriform -http://www.piriform.com/ccleaner/downloa...
    and install. It is free, there are two links you can use below the big green "Buy Online and Download" button in the middle, which is for paid support of the free program. Once you have it installed and open, click on the "Cleaner" tab if it is not already open. The program installs in safe mode so you do not have to worry about it removing anything critical to you OS. Look on Applications tab for anything in your browser that you might not want to be cleaned and unclick them. Click on "Run Cleaner" and let it clean. Next click on the "Registry" tab and clean everything, leave all the boxes marked. Click "Scan for Issues", after the scan, click "Fix selected issues" and let it clean everything. At some point it will ask you if you want to backup your Registry, select Yes and proceed with the cleanning. Make note of what file the bacup is in, just in case you need it. I've used this program many times on many systems and it has never failed. When it finishes, close and reboot the computer. After you reboot go to http://www.lacie.com/support/drivers/dri...
    and download the LaCie 1 Click Backup software and reinstall. Let me know how it goes.
What program do I use to open the backed up files?
What ever program you used to back up the files in the first place.
Did you use windows, or a different program ?
Are they stored on this
Verbatim 500GB USB Desktop 500 GB Hard Drive ?
When you use a program to backup a operating system, the program has the option to restore the system.
If you copied files onto another HDD, then you just copy them back.
You need to post what you used to do this.
Apr 13, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Is it ok to defragment my 2T goflex portable hard drive?
Yes. Defragmenting simply takes the pieces of empty space on the drive and groups them together. When you delete data from a drive or it is deleted as part of a program's function (such as deleting files only needed during installation) it leaves a blank space, but files are lined up on the drive. So if the files are like so:
2GB File ' 3 GB File ' 5.5 GB Free Space ' 1.5 GB File ' 4 GB Free Space
Then defragmenting would try to rearrange the files like so:
2 GB File ' 3 GB File ' 1.5 GB File ' 9.5 GB Free Space
So, in short, yes, it's okay to defragment your drive.
Mar 08, 2013 | Seagate FreeAgent GoFlex Desk Desktop...
I need to re-install my files & photos back to my computer
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps you
Sep 26, 2011 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
How to get back to factory settings
Have you created your Application/driver cd from start, system recovery?
To recover your system from the hard drive:
1 Remove all CDs and DVDs from the disc drives, disconnect all USB devices
except the keyboard and mouse, then disconnect your Internet cable. If you can still run Windows, click Start, All Programs, System Recovery, System Recovery, then click Yes. Your computer restarts, then the System Recovery program starts.- OR -Turn on or restart your computer and press F11 while your computer is starting.3 Insert the Operating System Recovery CD/DVD when prompted. The System Recovery program starts.4 Click a system recovery option:??  Full System Restore (Destructive) reformats the hard drive and restores the system software as it was when you purchased your computer. This process deletes your data files. CautionThe Full System Restore option deletes allfiles on your hard drive except the restorefiles. Make sure that you back up allpersonal data files before continuing thisprocess.??  Full System Restore (with Backup) (recommended) moves the contents of the hard drive to the C:\My Backup folder and installs a new copy of Windows XP. This option saves your existing data files, but all programs must be reinstalled and the program settings reconfigured. You need at least 4 GB of hard drive space to use this restore option.5 Click Next. The System Restore - Format and Recover dialog box opens.6 Click Yes. Files are restored to your hard drive. When file recovery has finished, the System Restore dialog box opens. ImportantAfter you restore your system, it willappear with the same files and programsit had when it shipped from the factory.You still need to download Windowsupdates and antivirus updates to bringyour computer's software up to date.7 Click Restart. Your computer restarts, and Windows finishes its setup and installation.8 Reconnect your Internet cable and all USB peripheral devices. You are done.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | eMachines ET183105 PC Desktop
External questions
I think you are asking about applications like MS-Office. Then surely you can transfer applications to external hard disc.
But for that you need to reinstall that applications. On instalation the application will ask you for the path for instalation. Then select the path as your external harddisc. This will complete the instalation and create shortcut on your desktop or Start - Programs.
Very important thing is if you want to run such applications you need to verify that the external hard disk is connected and working properly.
Thanks&Regards,
Current009
If it is helpfull to you then vote for me ......!!!!
Jun 30, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Write protected usb
download puppy linux, burn it to cd, plug usb, boot cd, open gparted, select usb, format usb. done
if u need the files in the usb, u can mount your hard drive and your usb, and copy the files...(use the first icon on the desktop)
May 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Iomega 500GB data corrupted
The boot info is bad. If there is info that is needed you will have to use a recovery program like getdataback fat 32 and getdatabackntfs
Aug 02, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Desktop Hard Drive hi Speed USB 2.0
should be able to go to START then click on MY COMPUTER......you should see this drive there and can open it or drag things into it
Jul 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I need all the start up files for a lacie hard drive
there this great program called Active Boot Disk, you can find it at http://www.ntfs.com/ its a program made to recovery any lost data from both NTFS and FAT32 hard drives, great software you should consider downloading it to restore your lost information.
Apr 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Drive C, full
Save all your files, your disk is risking to collapse at any time.
You cannot efficently run Vista on a 10 GB hard disk.
Minim efficient size it will be 40 GB or so.
Delete as many useless files as you can, use the hard drive cleaning tool that you find under all programs/accessories/system tools.
To save your file you can use the backup option in control panel, and save all files to an external USB stick or external hard drive or, do not use CD RW because the disk is full and there will be no space for disk image on hard drive.
If you want to keep using Vista I suggest replacing the hard drive for a bigger one.
Sep 05, 2008 | Computers & Internet
LaCie Hard Disk 750GB with Hi-Speed USB2.0 750 GB USB 2.0 Hard Drive Logo
132 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
