Question about Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
Toilet fills with water when flushed and drains slowly.
  • 2,100 Answers
It is clogged up, needs to be plunged, If you have a clean-out that you can peek in, see if the water flows by fast there or not, It could just be at the bowl. If not, you will need to snake the clean-out or the vent through the roof. I had a job once where the water stopped up and I couldn't find the clog, so I had to saw the pipe in a few places till I found it, and when I let it go, It went. All over the place. It was in 3 inch pipe that is supposed to drain, it didn't, so check it out, hope this helps.
Posted on Dec 29, 2010
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
  • 659 Answers
SOURCE: valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Posted on Apr 02, 2009
  • 62 Answers
SOURCE: basement toilet won't flush. water fills the bowl
Check your flapper line to the flush handle. The flapper is in the tank on bottom. There shoiuld be a plastic line to handle or chain. :)
Posted on Sep 07, 2009
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
AVibrating sound for 10 seconds- like a moan- after toilet is flushed and filled.What is going on? It doesn't happen every time.
Depends upon several things, the most difficult would be too much air in the pipes. Before having a "anti-hammer" installed; I would try this... go to the supply for the cold water pipe (for that room, dependent upon the age and style of your home) maybe the basement??? See if there is a place, other than the toilet, to turn off the water supply (turn the water off), open the cold water valves of your sink and tub and flush the toilet, and drain about 1 quart of water from that line. Leave the tub and sink cold water valves open and slowly open the valve you turned off, allow water to flow from the faucets and flush the toilet a few times. What you are trying to do is allow the air to escape. Turn off the faucets and flush the toilet again, open the partially closed valve all the way. This should get rid of trapped air, and it is the cheapest first step. This is one example of an "Anti-hammer" device.
Note: On some houses it may be difficult to find a place to drain the cold water line, without turning off the entire home.
Jan 15, 2018 | Home
Toilet is running
The most common reason for a toilet to continue to run is a problem with either the flapper or the entire flush valve itself. The water is slowly draining so the fill valve keeps running.
The flapper is the least expensive and easiest solution, so start their. It's usually around $5. If that doesn't solve the problem, I would purchase a flush valve kit, around $20, and replace your flush valve.
*Note: If you have to replace the flush valve, you have to take your toilet apart. Start with the flapper.
Feb 27, 2015 | Home
OCCASIONALLY HEAR SMALL LEAK COMING FROM BOTTOM OF TOILET...WATER BILL UNUSUALLY HIGH...(FAINT HISSING SOUND)
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl through the flush valve slowly...causing the tank to drain and the fill valve to run every few minutes or so. start by inspecting/cleaning or replacing the flapper and hopefully that will do it because a one piece toilet flush valve needs a special wrench,to remove it, that you use with a ratchet. If you buy a new flush valve, it comes with the wrench (glorified piece of plastic) and is not too difficult to get the flush valve out. you can get a replacement at http://www.plumbingpartsdepot.com/ They do mail order, too. All you need is the toilet type - a four digit number embossed in the tank starting with a 2. hope this helps but if you need anything else just ask:)
Jul 29, 2011 | Porcher VENETO II One-Piece Toilet -...
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
The flap will not stay up to allow the recommended 80 of the water to drain from the tank unless I hold the handle down. I have tried shorting the chain and increasing the water level. Nothing works!!!...
This toilet is a Water Sense toilet and it only uses 1.28 gallons per flush and no more. The tank is never going to completely drain with this low flush toilet. It is designed that way. Make sure the tank is filling to the fill mark inside the tank. If not adjust the fill valve until it does. Federal law says that a toilet can use no more than 1.6 gallons per flush. If you can take this toilet back and get a refund I suggest you do so and buy a Toto toilet. They are the best flushing toilet on the market. Watch it in action. http://www.youtube.com/watch?v=CmuzFve6O4k&feature=related
Dec 31, 2009 | American Standard Cadet 3 FloWise...
Super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Jun 16, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Apr 27, 2009 | American Standard Colony 2388.012.222...
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Dec 27, 2008 | Toto Drake ADA Compliant Toilet with...
Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
129 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
