Question about Sylvania G-Netbook
I've got a sylvania netbooklet model# synet7wid. Need help getting onto our home network (cable modem with Belkin wireless router)
  • Jeffrey Groves
    Jeffrey Groves Dec 29, 2010
    What have you tried so far?
    What issues have you encountered?
  • 600 Answers
Try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 29, 2010
Trying to connect to my Fast Access Wireless DSL Home Network. Continuously get the following message: REMOTE NETWORKING PPPoE Access Concentrator is not responding. Try again later. I have no clue...
Hi Sherole,
Sorry for the late reply. I need some more info before i can assist you properly. Is the Netbook connected to the Wireless network via cable or you trying to connect wireless? As i see it you are trying to do a dialup via your router which you dont really need.. If you can do the following for me. Press the start button then go Control Panel and Internet Options and then go to the Tab called Connections.. In the field where it says Dailup and Virtual networks what connections are listed?
Regards Gunter
Dec 27, 2011 | Sylvania G-Netbook
I have a Belkin wireless G router- 2.4Ghz-802.11g I have had for years. A few days ago it stopped connecting to the internet. I can connect my modem directly to my laptop and get on the internet so...
Start by checking for "link" between the modem and wireless router. This is usually a tiny light built into the network port itself on each piece of network equipment. It should be solidly on if the link is good. If it isn't on, check that you have the network cables plugged in good and that the cables or connectors are not broken or damaged. If you have another network cable, try it instead of the one you were using.
If these steps don't help, you can try fully resetting your wireless router to factory defaults, then reconfiguring it again. Consult the manual for your brand and model of wireless router for this. It may also have additional troubleshooting steps.
There is a chance your wireless router has simply gone bad. I've seen new Belkin wireless routers for as little as $29, so you may want to go that route, rather than spending too much time trying to troubleshoot the one you have.
May 19, 2017 | Belkin Pre-N (F5D8230-4) (DBF5D82304)...
We have four computers with a Belkin 54g wireless router. One computer is connected to our dsl bya cable. The other 3 are using wireless. Whenever one of the computers gets on the network, neither of...
You need to attach the Belkin 54g wireless router to the DSL/cable modem. Then have all the computers connect wirelessly to the belkin. They should then be able to get out.
Jan 11, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Router not working right
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
Please rate if helpful.
Thanks
Apr 14, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
How to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
Oct 14, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Sylvania G-Netbook Logo
388 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
