SLIGING DOOR FOR SINGLE CD IS BROKEN
MY CD WAS BOLCK IN THE SLIDING DOOR AND THE DOOR STOP TO OPEN AND CLOSE SORRY FOR MY ENGLISH I SPEAK IN FRENCH ALL THE TIME
  • 2 more comments
  • KOBEL999 Jul 07, 2008
    I AM SORRY ITS A CD MULTI PLAYERS NOT A DVD PLAYERS
    I OPEN THE CASE WITH A SCRUDRIVER AND THE CD IS NOT IN THE DRIVER NOW.........BUT THE AUTOMATIC WELLS IS BROKEN.......
    IM LOOKING FOR A RéPARATORS IN MY ARéA
    I LIVE AROUND OTTAWA CITY CANADA
    YES I NEED A REPAIRS BUT I DONT KNOW WHERE IS THE STORE FOR HITACHI SONG SYSTEM REPAIR IN MY COUNTRY.......I LIVE IN OTTAWA CANADA
  • KOBEL999 Jul 15, 2008
    thanks for your help......... my problem is ok now thanks again
    Sergeant:
    Champion:
  • 417 Answers
If the door opens and closes dvd player may be faulty
if the DVD tray wont open the disc is stuck inside try Turing it off by the power point wait 3 seconds then back on if disc still doesn't come out (YOU) may need to be remove manually which you need to take it apart
Posted on Jul 07, 2008
  • nicholas Rokkasarno
    nicholas Rokkasarno Jul 07, 2008
    if the door opens and closes cd player may be faulty
    if the cd
    Had a Damage Circuit board And Needs Repair
    nicholas Rokkasarno Jul 15, 2008
    NO SORRY
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
Unable to open cd tray on Philips DVDR7300H message reads :bolcked"
I just had the same problem. I opened up my player (hex key, allen wrench), removed the disc drive, the magnetic cover (regular crosshead screws) and the slide tray. The rubber band that connects to the motor to push the tray out was broken. I replaced the rubber band, put it back together and it worked perfectly. Hope that helps.
Oct 23, 2010 | Philips Televison & Video
Display flashing Hello and clunking sound from DVD RW. Will not change from Hello nor will it open or close
sounds like you have broken piece moving around on the inside or broken dvd inside my youngest son put a music cd in my dvd player and didnt put it in right and it broke causing player to make clunking sound and door refused to open. The broken cd was found when player was opened up and sorry to say the tray was broken because of it
Aug 09, 2009 | RCA DRC8030N
Stopped recording/won't open door for disc at all
There's a slot on the bottom where you can insert a small slotted screwdriver and slide it to the left to get it open.
Apr 03, 2009 | iLO DVD Recorder DVDR05
LG DR4912 - Optical drive motor bouncing of the end stop.
Mine was doing the same.last night i opened up the machine & took out the cd drive and opened it up.I cleaned the laser with a cotton swab and manually pushed the laser back to the front of the unit as far as it could slide on the 2 little posts it slides along.
Dec 30, 2008 | LG DR-4912 DVD Recorder
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
My dvd eill not speak in english
Your problem is not the DVD player, most DVD's come in multi-language format and your disk is set to either French or Spanish. Correct the setup when the DVd begins.
Nov 28, 2007 | Audiovox D1708 Portable DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
DAEWOO DVG-9100N DOOR WONT CLOSE
ok! that is mechanical problem! you have loose belt drive change it! or mechanical switch or timing switch that sensor to open or close. clean all the switch. you found the switch under the tray of the CD plate.
Jul 22, 2007 | Daewoo DVG-9100N
Televison & Video Logo
389 people viewed this question
Top Televison & Video Experts
Electro Med Services...
