Question about GE 168947 Toaster Oven with Convection Cooking
The numbers onthe front of the oven were rubbed off after a hard cleaning I need a picture of the front of this oven in order to know were the settings go thanks
Euro-Pro Bravetti Model To283B
You may have to start all over again with a replacement oven. Never, never, never use oven cleaner in this type of appliance!
Oct 13, 2013 | Euro-Pro Toaster Ovens
How do we change the heating element. It was hit and broke but not in half so we need to remove it and add a new one.
I ordered bulbs online at http://www.smallappliance.com/ They come in a set of 6, you can't order less than that, I looked all over the place. Here is the part number: Krups SS-185303 Heating Element. You might want to find them on Amazon.com because by the time you order them from the above website, with shipping, it will come to more than you will pay total on Amazon and it's coming from the same place. Just in case Amazon doesn't have them in stock (you never know) I wanted to give you the source for the bulbs.
  1. Unplug unit and remove all trays and racks and crumb tray. (I took this time to do some much needed deep cleaning too.)
  2. First you have to remove the old bulb. I tried it the hard way by trying to pull it out - it's connected with screws on the left and right to the connector wires.
  3. I placed the oven on a big light colored towel and had a cup ready to place all my screws in. I also took pictures of it before I started taking it apart so I had something to reference when putting back together. I used a small sharp phillips head screw driver, DW40, household oil, a set of leather household gloves and patience.
  4. I first removed the cover of the whole oven by starting with the bottom legs (there's a screw under the rubber foot), the bottom, back and then removed screws on the face/door. Becareful of the door hinge. You might want to use some household oil or DW40 before you start to attempt this. My oven is 6 years old and we've used it everyday. There was some accumulated stuff around the screws.
  5. Carefully remove cover of oven and door/face. There's going to be a thick wire that will connect the interface circuit board to the internal boards so again, becareful when removing the face of the oven. The glass door may pop out of the hinge so, again, becareful.
  6. Make sure and observe how the door hinge and spring are placed and take a picture as you're going to have to put it back together.
  7. When I got to the connector of the bulbs I had to use, very carefully, some more household oil on the screw.l I held the ceramic socket with my leather utility gloves on and gently applied pressure to get the screw loose on both sides.
  8. Carefully place new bulb in hole/holders and gently screw the wires back on, start with the right side (facing the oven).
  9. Reassemble the door hinge if you took it off. and place the face on just for position.
  10. Attach the outer cover, back first and then bottom.
  11. Attach face and make sure hinge is working properly and you've tucked that wire back in.
  12. Attach legs.
  13. Remove anything else plugged into socket you use for the oven (just in case it blows the socket which has happened with some DIY repair in our house). Plug in oven and test it out.
  14. I hope this has helped you. If not, find some coupons for Bed Bath and Beyond and purchase a new one and sell your extra bulbs on ebay or craigslist. Good luck!
Jul 10, 2011 | Krups FBC2 1600 Watts Toaster Oven with...
How do i order a door handle for an convection toaster oven?
Go to parts select.com and type in the make and model number. They have parts for whatever you need. If not there, try partsdirect.com. Hope this helps
Jan 22, 2011 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
I need to purchase a replacement for my toaster over #6233 - I need a new Baking Pan & Broiling Tray. Mine is very soiled and will not clean
FYI Oster Toaster Oven: about 18 months ago after careful consideration we purchased a counter top toaster oven for the RV from WalMart. I have a 20+ year old Oster Kitchen Center and found easy access to repair parts a couple of years ago, very pleased.
Last trip out in the RV the timer knob stripped out after what I would describe as a couple of months of light use. Google'd the model in search of a replacement knob only to find many others had "been there, done that". The model is obsolete and no service parts are available.
The Oster customer service rep seemed finished at this point and asked if there was anything else she could do for me. I asked what I, a long time Oster customer, should do with the useless oven. After repeating the question rephrased several different ways she put me on hold.
She returned several minutes later to inform me that as a "one time" courtesy Oster would replace our out of warranty oven with a current model. The replacement unit would have no warranty or support from Oster.
She supplied the model number and gave us an Order #. Looking up the model number and checking reviews I have very low expectations for the replacement. Most comment as to the poor quality and reliability of this current model.
A perfect example of a manufacturer who once produced a quality produce but now sells cheap imported disposable products.
YMMV
Nov 07, 2010 | Oster 6232 / 6233 1500 Watts Toaster Oven...
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Hi! I need a toaster control knob from the front of my model KC01005 toaster oven. Where can I get one? Thanks, Bill
Try the kitchen aid site, Email them with the model number and let then know what you need and the price of it. Sometimes with the part being small, they will send it free of charge
Apr 04, 2010 | KitchenAid KCO1005OB 1400 Watts Toaster...
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Need a knob for the oven broiler on a welbilt
I needed a new timer knob as weel. I contacted KitchenAid's customer satisfaction Center at 1-800-541-6390, and they sent a new one to me at no charge.
Jul 13, 2008 | Toaster Ovens
GE 168947 Toaster Oven with Convection Cooking Logo
47 people viewed this question
Top GE Toaster Ovens Experts
Mack Baxter
Tom Chichester
Bill Boyd
Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
