Question about Casio DB360G-9A 30 Pages Telememo Watch
Como le pongo la alarma - Casio DB360G-9A 30 Pages Telememo Watch
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
Torgoen - T27105 n'est marche pas,je vient juste de l'acheter mais il marche pas
Lis les instructions de mise en marche de la montre. Lis aussi la section en cas de probl`eme. Si elle refuse de se mettre en marche, retourne au magasin et demande un remboursement. La prochaine fois que tu veux acheter une montre demande au marchand de v'erifier le bon 'etat de marche.
Jan 28, 2014 | Torgoen T27105 T27 Pilot Watch
How to change a timex wr50m from military time to regular time
in the setting after you have set the date, you have to choose whether 12 or 24. choose 12.
Jul 14, 2011 | Watches
Com0 obtenfo el manual de codigos de tv para el casio cmd30
como obtengo el manual para programar el reloj para controlar la tv
May 04, 2011 | Casio CMD30B Watch
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
J ai acheté une montre armani et jai un probleme pour réglé la date chaque fois nous somme le premier du moi elle affiche 02 au lieu du 01
Appuyer avec un objet pointu sur le minuscule contact flanc gauche de la montre. De même à droite pour phases de lune
Oct 01, 2010 | Giorgio Armani Armani Automatic AR4211...
How do i set the time on a dunlop sports watch?
Ma montre , spur DUNLOP dun 103 g10 , est pourvue d'une feuille explicative concernant un mod?le diff?rant !
2 personnes ont pass? des heures ? essayer de la r?gler sans succ?s
comment ? puis-je la rendre fonctionnelle ?
Merci de votre r?ponse
Meilleures salutations
Gerry GRAEF
50, rue du Premier-Mars
CH-2206 Les Geneveys-sur-Coffrane
Sep 23, 2010 | Bulova Watch
Monsieur, dans le menu "option" quand je valide , l'écran m'affiche "locked", comment faire pour dévérouiller . Merci d'avance pour votre réponse rapide.
Merci d'avoir contact? FixYa.
D?sol? mais vous devez communiquer avec Polar. Voici le lien et vous aurez besoin de changer la r?gion dans le coin sup?rieur droit.
http://www.polarusa.com/us-en/
Sep 14, 2010 | Polar S-725 Wrist Watch
Casio DB360G-9A 30 Pages Telememo Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
