Question about Whirlpool WTW58ES Top Load Washer
I have a wtw58esvw1, 2 year old whirlpool top load that had a broken wire at the motor start cap, I repaired it but now there is no voltage going to the mixing valve. I have downloaded the parts list but needing a service manual. I thought it was unlikely that I have two unrelated problems.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Calypso Top Loader
The wash plate (or nunater) can be removed by following these instructions. It may seem like a lot, but the wash plate will not come out of the tub unless you follow the necessary steps: 1. UNPLUG THE WASHER. 2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. 3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal. 4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it. 5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Your clothing is probably tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Good luck to you and I hope this helps you. PS Don't forget to put the tub ring back in.
Posted on Sep 19, 2007
SOURCE: Washer Spins But Clothes Still Wet
I replaced the Clutch Assembly.
Posted on Dec 11, 2008
  • 3230 Answers
SOURCE: HF error code
hi,
check this-
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
good luck
Posted on Mar 28, 2009
  • 212 Answers
SOURCE: No Power at Control Panel
sounds like a fuse issue. check the fuses.
Posted on May 24, 2009
  • 670 Answers
SOURCE: I am looking for a PDF service manual for
Take this link to Whirlpool website and the manual is yours. http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSC8244EZ1&siteCd=WHRCOM
Posted on Jun 30, 2009
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Whirlpool Ultimate care II doesnt' advance through
Lean washer on its back and check for broken wire from the motor wire harness up the back panel.
If you find the wire repair it and make sure the wire harness is secure in the provided clips.
Jan 21, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Our LSR7233HQ0 washer is 10 yrs. old and the agitator stopped spinning. Any repair tips?
You may have broken the drive belt. Can you hear the motor spinning still? If yes, then it is definitely a broken drive belt.
Oct 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool heavy duty thin twin broken heater, the dryer just stop heating, please help I can repair my self, unit is about 6 years old and it works grat
Hi, thanks for the inquiry.
If it's a gas dryer, it's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
If it's an electric, it's either the heating element or the thermal cut-off, most of the time.
You'll proabably have to get to the element and fuse from the back. What I would do is just tilt the entire unit forward, if it's in a tight closet.
Best of luck and please feel free to contact me if you have any questions.
Ned
Sep 21, 2009 | Whirlpool LTE6234D Top Load Stacked...
My Kenmove washing maching does not agitate. You
This is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
There is a Sears repair parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=11029852992
which you can go to to see all of the components.
Since it isn't agitating (I assume not at all rather than just the top part of the agitator. If just the top part isn't turning then the easiest solution is replacing the 4 "agitator dogs" ) the solution points to a couple of places.
1. The motor coupler
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:3364003Substitution:285753A $18.50 In stock
may be broken. This piece is a fail safe between the motor and transmission. and basically transmits power to the transmission.
If it spins and drains OK, and if you can hear the motor turning, the problem points to the transmission.
Inside the transmission are a number of gears, springs, and plastic cams and levers. Over time one of them may have either broken or worn out.
moz-screenshot.pngThere is a Whirlpool site with a parts list for their "commercial washer" which is essentially the same as for your washer. On it is a list of all of the components and parts for the washer.
By paging down to and following the diagram of the transmission you should be able to determine which actual part is broken.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
When our washer (12 years old) wouldn't spin, rather than spending $170 for a new transmission, we installed a repair kit into the old one ($15) and the problem was solved.
Sep 15, 2009 | Kenmore Washing Machines
I have an average top load washer that is 11 years old. The tall agitator in the middle isn't agitating. Thank you.
Assuming that this is the basic Kenmore / Whirlpool top load, direct drive, neutral drain two piece agitator model.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and a list of major sub-components will come up.
couple of places.
Sep 07, 2009 | Kenmore Washing Machines
15+ year old Whirlpool top loading washer spin cycle broken.
Check the solenoid operation on the outer one that operates the spin bar. There are two solenoids that move back and forth all the time when running called wig wag solenoids. Check for broken wires and movement of the outer slide bar that shifts to make spin. It may need lubrication. Go to www.appliancepartspros.com to get a diagram.
Apr 15, 2009 | Whirlpool LSB6200KQ Top Load Washer
Code CE
CE stands for Communication error. The Calypso has 2 circuit boards inside that touchpad area. One is the motor control board and the other is the machine control board. They are not "talking" to each other for some reason. The boards are warranted for 5 years on most machines. This machine is the subject of a class action lawsuit. Just Google Whirlpool Calypso sit back and start reading.
Dec 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
F 51. I know its a fault.
It is a rotor position sensor code. The control is no longer recieving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor. If the machine is less than a year old, it will be repaired in warranty. If not, post back and I will try to walk you through the repair if you want to try it.
Oct 21, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW58ES Top Load Washer Logo
128 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
