Question about Hitachi P50H401 50 in. Plasma HDTV
Hitachi P50H01AU 50" Plasma in the last few day
  • 1779 Answers
SOURCE: my plasma has a thin black horizontal line
You can either have a bad Y-Upper buffer board, or dirty contacts on the plug associated with the horizontal line. Best to have a service company look at it.
Posted on Jul 24, 2009
  • 927 Answers
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
SOURCE: Black line down the center of screen
I had the same problem to and I fixed it.
At the bottom of the plasma there are six or seven ribbon cabbles that come out of the panel and connect to like driver boards. Each ribbon drives that section of the panel. Mine had it down the centre so I unplugged that ribbon cable and on the underside of a metal plate attached to it there are four big resistors and four small ones. The big ones labelled 100 required resoldering. Once they were resoldered it worked just fine.
Posted on Sep 24, 2008
  • 58 Answers
SOURCE: 50 inch samsung plasma that is 3 years old
not necessarily, sometimes the connectors that feed the screen get old and dirty
If you have some electronic skills, open the TV and clean the connectors around where you see the symptoms and you may have a good chance to get if fix by doing that...
good luck
Posted on Jul 15, 2009
Hitachi-mex
  • 26 Answers
SOURCE: vertical lines on plasma tv
Maybe is a lose contact in the conectors of the screen.
You need disconect the conectors, clean with isopropilic alcohol, and reconect the conectors.
Posted on Jul 18, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
How to repair my Samsung Plasma, it has horizontal black lines across the screen.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 12, 2015 | Samsung PN50C450 50 in. TV
Horizontal lines
Contact the authorized service center for Hitachi. Never do any more adjustments. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 25, 2014 | Hitachi P50H401 50 in. Plasma HDTV
Two horizontal lines going across the screen
hi i have the same tv mine just started doing this last week were you able to fix the problem if so wht was it
Dec 02, 2012 | Samsung PN50B550T2FXZA PN50B550 50 Plasma...
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Good Day, LDS also;
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi P50H401 50 in. Plasma HDTV Logo
218 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
