Question about Keurig B60 Coffee Maker
I have had my Keurig B60 for about a year and a half. This morning, I added water to the reservoir; it heated up and said ready to brew. I pushed the button and the brewing sound did not start. A few drops fell into the cup, but no brewing happened. Is there anything that I can do to fix this? I no longer have the original box or receipt and I think the coffee maker should last longer than this..Thank you for your help. Sincerely, Gladys Kruschwitz
  • gkruschwitz Dec 30, 2010
    and if no power is being supplied, does that mean I should just have gone ahead and got a new coffeemaker without spending and extra $5?
  • gkruschwitz Jan 02, 2011
    Well, I have to say the Internet is full of strange and helpful people. I followed the directions for both segments, and my machine is brewing again. I was just getting ready to go out and buy a new one today. I have saved myself $130 ! Thanks a lot. I saved the YouTube links to share with other people. Too bad Keurig doesn't include these in the directions manual! thanks again. It was worth the $5 to find these videos; I guess I could have gone on YouTube myself but never would have thought to do it!
  • Keurig Master
  • 1,711 Answers
We have
here below a video link which is specifically for your case. The video is so
clear that we thing that any other words are useless.
http://www.youtube.com/watch?v=DqRs4Ott21s&playnext=1&list=PL88559E01E8136AA5&index=35
This one
will help if the above have not work out
http://www.youtube.com/watch?v=nIBvzWWI-LY&feature=related
If it does
solve your problem try also to do de-scale often
http://www.youtube.com/watch?v=l8diybgU6E0&feature=related
Posted on Dec 30, 2010
  • snapshot4 Jan 18, 2011
    So I had this same problem the fix was pretty simple. Air had gotten into the fill line and the pump couldn't pump the air filled line. So to get rid of the air try to brew a cup of coffee (make sure you have a cup under) now cover the over flow at the top of your water reservoir with your finger or thumb. Air bubbles should blow into you water storage tank. Once the bubbles are gone remove your thumb or finger. Now try to brew a cup of coffee again.
    --snapshot4
    Sergeant:
  • 163 Answers
It sounds like the pump may have died. To verify that, you would have to open up the coffee maker and see if the pump is being supplied any power when you push the button to brew.
Posted on Dec 29, 2010
Keurig just keeps saying add water
The water passages are clogged and triggering this warning.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Oct 17, 2014 | Keurig Coffee Makers & Espresso Machines
Kureig heats but won't brew
The exit needle could be clogged located( inside bottom of the holder assembly). Remove K-cup assembly and detach funnel. Insert a paper clip or simiilar tool into the exit needle to loosen the clog and push it out. REMEMBER, the needles are very sharp, proceed with caution!!
You may also need to Descale your Keurig...I do this every other month due to high mineral content in my potable water. Change out resevoir filter and clear exit needles as part of Descaling. Disable "auto shut off" feature, remove reservoir filter and do not use a kcup prior to proceeding. Place 48ounces of white vinegar into reservoir, press brew, discarding each mug of water down kitchen drain and repeat until "Add Water". Let brewer stand for four hours in "On" . Rinse after 4 hours by filling water reservoir with fresh water and press brew until ADD WATER is indicated.
I run two full fresh water cycles before actually using the Keurig for beverages I will consume.
Hope this helps
Nov 17, 2013 | Keurig B60 Coffee Maker
My Keurig B60 will not brew. The "ready to brew"
Having same problem with B60 turns off after 1 minute and little circle won't go away.After unit was stored for 5 months, So this is what I did. 1. I took it over to the sink and turned it upside down and shook it. 2. I dried out the whole where the water sucks up and blew through there with a straw. 3. then I sucked water out the rubber tube up top for the over flow. Then I put vinegar in the intake whole and put vinegar in the tank and let it sit overnight. When I got up in the morning i turned it on and after 1 min it shut off again so I restarted it and after a couple minuets it started to heat and my display came back and circle disappeared. Problem solved. Not sure which one worked but it is now working fine and I am now descaling it.
Feb 25, 2011 | Keurig B60 Coffee Maker
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
2,579 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
