Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
How can I install the heater? - Williams 3003622 Ceramic Wall Mounted Panel Heater
Can you please describe the electrical specifications on the unit and in the manual (i.e. amps, electrical phase (single or 3 phase) and voltage requirement)? This will dictate the install.
Does the unit have a motor or fan?
Posted on Dec 29, 2010
  • wgrochowski Dec 29, 2010
    Sorry. I just realized this a natural gas unit. My expertise is electrical.
Heater core leaking through floor vents.
Bad heater core you will need to replace it. About a 2 hour job, very easy to do:
Remove the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
Remove the HVAC filter cover.
Remove the heater core/evaporator tube seals from the module.
Remove the heater core cover screws (1).
Remove the heater core retaining screws (1).
Remove the heater core retaining straps.
Remove the heater core.
Remove the rubber seals from the inlet/outlet pipes of the heater core.
Installation Procedure
Install rubber seals to the outlet/inlet pipes of the heater core.
Install the heater core to the module.
Install the heater core retaining straps.
Install the heater core retaining screws (1).
Install the heater core cover.
Install the heater core cover screws (1).
Install the heater core/evaporator tube seal from the module.
Install the HVAC filter cover.
Install the HVAC module assembly. Refer to HVAC Module Assembly Replacement.
May 19, 2011 | Cadillac DeVille Cars & Trucks
Heater core replacement. Haynes manual and car have major differences.
Heater core is removed from inside the cabin. About a two hour job. The hardest part is removing the hoses in the engine bay.
In the cabin, remove the beauty panel under the glovebox; remove the glovebox, and move the HVAC controller. The heater housing, or cover is held with two screws, and the core is held with one screw (clamp).
This is the best that I can do for you, hope this works
May 19, 2011 | 1998 Cadillac DeVille
How do i replace a heater core in my 97 blazer
Heater Core Removal & Installation To Remove:
  1. Remove the heater/vent module.
  2. Remove the heater core access cover screws.
  3. Remove the heater core access cover.
  4. Remove the heater core from the heater/vent module
To Install:
  1. Install the heater core to the heater/vent module.
  2. Install the heater core access cover and screws to the heater/vent module.
  3. Install the heater/vent module assembly to the vehicle.
Dec 19, 2010 | 1997 Chevrolet Blazer
Broken heater coil
If you mean the heater core is leaking. Here is how to change it:
To Remove:
  1. Remove the HVAC assembly.
  2. Remove the heater core cover screws.
  3. Remove the heater core cover from the HVAC assembly.
  4. Remove the heater core gasket from the core.
  5. Remove the heater core from the HVAC module assembly.
To Install:
  1. Install the heater core to the HVAC module assembly.
  2. Install the heater core cowl gasket to the HVAC module assembly.
  3. Install the heater core cover and screws to the HVAC module assembly.
  4. Install the HVAC module assembly to the vehicle.
Oct 18, 2010 | 2000 Chevrolet Silverado 1500
To Install:
Oct 08, 2010 | 2003 Chevrolet Blazer
Diagram on how to replace heater core in 99 expedition
Removal & Installation 1997-2002 To Remove:
NOTE: Heater core must be vacuum leak tested before it is remove from vehicle if a heater core leak is suspected.
  1. Drain engine coolant.
  2. Remove instrument panel.
  3. For 5.4L (4V), if quipped, remove junction splash shield.
  4. For 5.4L (4V), if quipped, disconnect starter relay cable. ford-03-00-3579.gif
  5. For 5.4L (4V), if quipped, remove junction block bracket.
  6. Clamp inlet and outlet heater hoses.
  7. Disconnect heater hose from heater core by gently pressing it toward heater core.
  8. Remove A/C plenum demister adapter.
  9. Disconnect vacuum line.
  10. Remove 13 plenum chamber top screws.
  11. Remove blend door assembly from case.
  12. Remove heater core.
To Install:
NOTE: If needed, clean and lubricate coolant hoses with plain water.
  1. Install heater core.
  2. Install blend door assembly to case.
  3. Install 13 plenum chamber top screws.
  4. Connect vacuum line.
  5. Install A/C plenum demister adapter.
  6. Connect heater hose to heater core.
  7. Release all clamps from inlet and outlet heater hoses.
  8. For 5.4L (4V), if quipped, install junction block bracket.
  9. For 5.4L (4V), if quipped, connect starter relay cable.
  10. For 5.4L (4V), if quipped, install junction splash shield.
  11. Install instrument panel.
  12. Refill engine coolant.
Aug 21, 2010 | Ford Expedition Cars & Trucks
REPLACING HEATER CORE
HEATER CORE REPLACEMENT REMOVAL PROCEDURE 1. Remove the fuel injector sight shield. 2. Drain the cooling system. Refer to Draining and Filling Cooling System in Cooling System. 3. Use J 38185 in order to position aside the heater hose inlet and outlet clamps at the heater core. 4. Disconnect the inlet and outlet heater hose from the heater core. 5. Remove the RH Instrument Panel Closeout/Insulator panel. 6. Remove the LH Instrument Panel Closeout/Insulator panel 7. Remove the floor carpet. 8. Remove the rear floor air outlet duct from the holes in the floor reinforcement. 9. Disconnect the rear floor air outlet duct from the heater air outlet cover. 10. Remove the rear floor air outlet duct. 11. Remove the heater air outlet cover screws . 12. Remove the heater air outlet cover heat stakes with a small chisel. 13. Remove the heater air outlet cover from the HVAC module assembly. 14. Remove the heater core cover screws . 15. Remove the heater core cover heat stakes with a small chisel. 16. Remove the heater core cover from the HVAC module assembly. 17. Remove the heater core from the HVAC module assembly. 18. Remove the heater core foam seal (1) from the HVAC module assembly.
INSTALLATION PROCEDURE 1. Install a new heater core foam seal to the HVAC module assembly. 2. Install the heater core to the HVAC module assembly. 3. From the inside of the heater core cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 4. Install the heater core cover to the HVAC module assembly. NOTE: Refer to Fastener Notice in Service Precautions. 5. Install the heater core cover screws . Tighten Tighten all screws to 1.5 N.m (13 lb in) . 6. From the inside of the heater air outlet cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 7. Install the heater air outlet cover. 8. Install the heater air outlet cover screws (2). Tighten Tighten the screws to 1.5 N.m (13 lb in) . 9. Connect the rear floor air outlet duct to the heater air outlet cover. 10. Install the rear floor air outlet duct to the holes in the floor reinforcement. 11. Install the floor carpet. 12. Install the RH Instrument Panel Closeout/Insulator panel. 13. Install the LH Instrument Panel Closeout/Insulator panel. 14. Connect the inlet and outlet heater hose to the heater core. 15. Use J 38185 in order to reposition the heater hose inlet and outlet clamps to the heater core. 16. Install the fuel injector sight shield. 17. Fill the cooling system.
Nov 13, 2009 | 2003 Chevrolet Monte Carlo
Need to remove heater core from 2000 Daewoo Nubira
  1. Disconnect the negative battery cable.
  2. Remove the instrument panel from the vehicle.
  3. Remove the heater/air distributor case from the vehicle.
  4. Disconnect the vacuum actuators from the vent/floor door and the defroster door.
  5. Remove the vacuum actuators from the heater/air distributor case.
  6. Remove the screws that secure the heater core cover to the heater/air distributor case assembly.
  7. Slowly separate the lower heater core cover from the rest of the assembly
  1. Remove the screw and the bracket clamp that secure the heater core lines to the case.
  2. Remove the spring clamp that secures the heater core body to the case.
  3. Remove the heater core from the case.
  1. Install the heater core into the case.
  2. Secure the heater core lines to the case with the retaining bracket clamp and the screw. Tighten the heater core retaining bracket screw .
  3. Install the heater core body with the retaining spring clamp.
  1. Install the heater core cover.
  2. Install and tighten the screws that secure the heater core cover to the heater/air distributor case assembly. Tighten the heater core cover screws
  3. Install the actuators for the vent/floor and the defroster doors.
  4. Install the heater/air distributor case.
  5. Install the instrument panel.
  6. Fill the cooling system
  7. Connect the negative battery cable.
Jun 18, 2009 | 2000 Daewoo Nubira
Blown heater core in a 1977 ford f-150 pick-up
1976-79 Without Air Conditioning
  1. Disconnect the temperature and function control Bowden cables from the heater housing. This must be done to prevent damage to the cables.
  2. Disconnect the wires from the blower resistor.
  3. Remove five screws attaching the air inlet (vent) duct to the heater housing.
  4. Disconnect the blower wires.
  5. Drain the radiator and remove the heater hoses from the heater core.
  6. Remove three heater stud retaining nuts and remove heater.
  7. Remove gasket between the heater hose ends and the dash panel at core tubes.
  8. Remove heater core cover and gasket (four screws).
  9. Pull heater core and lower support from heater.
To install:
  1. Install foam gaskets on heater core and install in heater assembly.
  2. Install the core seal and cover plate.
  3. Position heater assembly in vehicle and install three stud retaining nuts.
  4. Connect heater hoses to heater core and fill radiator.
  5. Connect blower motor wires.
  6. Place defroster nozzle on heater so that the defroster and heater openings are in the up position, and there is no air leak around the seal.
  7. Install air inlet (vent) duct to heater. Push duct firmly against seal on side cowl and tighten five attaching screws.
  8. Connect wires to blower motor resistor.
  9. Connect temperature and function control cables to heater, and adjust the cables.
  10. Reinstall gasket between the heater hose ends and the dash panel at core ends.
  11. Fill Cooling System.
  12. Hope this helps you! Please remember to rate my solution.
    Lefty64
Apr 09, 2009 | 1986 Ford F150 SuperCab
Changing a heater core
here is a step by step diagram to replace your heater core
Front
  3. Remove the instrument panel glove compartment.
  4. Tag and unplug all electrical leads as necessary.
  5. Remove the center air distribution duct from the floor.
  6. If necessary, remove the ECM and mounting tray.
  7. Remove the hinge pillar trim panels.
  8. Remove the blower motor cover and then remove the motor.
  9. Remove the steering wheel and tilt back the instrument panel slightly.
  10. Remove the coolant overflow tank. Disengage the heater hoses at the core connections.
  11. Unfasten the attaching screws and nut and then remove the heater case.
  12. Remove the seven screws and lift off the heater case cover.
  13. Remove the fasteners and brackets that hold the heater core to the case and lift the core from the case.
To install:
  1. Install the heater core in the case.
  2. Install the heater case bottom plate. Make sure there is a good seal.
  3. Install the heater case into the truck. Tighten the 4 lower screws to 17 inch lbs. (2 Nm); the upper screw to 97 inch lbs. (11 Nm); and the nuts to 25 inch lbs. (2.8 Nm).
  4. Connect the heater hoses at the core tubes.
  5. Install the coolant overflow tank.
  6. Install the instrument panel and the steering wheel.
  7. Install the blower motor and cover.
  8. Install the trim panels and if removed, the ECM. Install the air distribution duct and reconnect all electrical leads.
  9. Install the glove compartment. Fill the cooling system and connect the battery cable.
  2. Drain the engine cooling system into a clean container for reuse.
  3. Disconnect the heater hoses from the heater core.
  4. Remove the instrument panel storage compartment.
  5. Disconnect the electrical connectors, as necessary, that may be in the way.
  6. Remove the center floor air distribution duct.
  7. Remove the hinge pillar trim kick panels.
  8. Remove the blower motor cover screws and the cover.
  9. Remove the blower motor screws and the blower motor.
  10. Remove the steering wheel and the steering column (standard & tilt).
  11. Remove the instrument panel fasteners and pull the instrument panel back far enough to gain access to the heater assembly.
  12. While holding the heater assembly against the firewall, remove the screw located on the interior side near the evaporator pipe, if equipped.
  13. In the engine compartment, remove the 4 heater assembly-to-chassis screws and the 2 heater assembly-to-chassis nuts.
    NOTE Removal of the heater assembly may require the help of an assistant.
  14. Remove the 7 heater cover-to-heater assembly screws and the cover.
  15. Remove the heater core from the heater assembly.
    93113g80.gif View of the front heater assembly—Chevy/GMC C/K-Series, Blazer, Jimmy, Sierra, Suburban, Tahoe, Yukon
    Click to Enlarge
    93113g81.gif Location of the front heater assembly-to-chassis fasteners—Chevy/GMC C/K-Series, Blazer, Jimmy, Sierra, Suburban, Tahoe, Yukon
    Click to Enlarge
To install:
  1. Install the heater core to the heater assembly.
  2. Install the heater cover and the 7 heater cover-to-heater assembly screws.
    NOTE Installation of the heater assembly may require the help of an assistant.
  3. In the engine compartment, install the 4 heater assembly-to-chassis screws and the 2 heater assembly-to-chassis nuts. Torque the screws to 17 inch lbs. (1.9 Nm) and the nuts to 25 inch lbs. (2.8 Nm).
  4. While holding the heater assembly against the firewall, install the screw located on the interior side near the evaporator pipe, if equipped. Torque the screw to 97 inch lbs. (11 Nm).
  5. Install the instrument panel and the instrument panel fasteners.
  6. Install the steering column (standard & tilt) and the steering wheel.
  7. Install the blower motor and the blower motor screws.
  8. Install the blower motor the cover and the cover screws.
  9. Install the hinge pillar trim kick panels.
  10. Install the center floor air distribution duct.
  11. Connect the electrical connectors that were disconnected.
  12. Install the instrument panel storage compartment.
  13. Disconnect the heater hoses to the heater core.
  14. Refill the engine cooling system.
  15. Connect the negative battery cable.
  16. Run the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Dec 31, 2008 | 1994 Chevrolet C1500
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
47 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
