Question about Panasonic Lumix DMC-ZS3 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
  • 2,296 Answers
The images will be saved to a SD card if one is inserted, or to the built-in memory if not. This means that the SD card that you have inserted is not supported by your camera.
The following SD standard-based cards are supported by your Panasonic camera:
- SD memory cards (8 MB - 2 GB)
- SDHC memory cards (4 GB - 32 GB)
Can only be used with devices compatible with SDHC memory cards.
- Cards of over 4 GB may only be used if they have the SDHC logo.
Posted on Dec 29, 2010
    Brigadier General:
  • 11,967 Answers
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
2 Suggested Answers
  • 903 Answers
SOURCE: SD card
Once connected to your PC you can copy virtually any file to the SD card and transport it home. However, in doing so you do risk the possibility that the camera may not be able to properly display the existing images on its LCD screen. The files won't be damaged, so they can be manually copied to the PC afterwards. In a similar situation, .JPG images you obtain from other sources can be coped to the SD card for temporary storage, but the camera may not display them properly. In any of the above cases when a problem is experienced, manually copy the files to te PC anf reformat the SD card IN THE CAMERA.
Posted on Sep 04, 2005
My D-551rxt shows taking pic but its not
Are you familiar with digital cameras?
The SD card is the storage device of the camera and if any pictures are taken, they will be stored in there.
Provided your SD card is locked, your camera cannot store any pictures.
Switch off your camera, remove the SD card and look at the sides, you will find a tiny slide switch. slide it away from the label that reads 'lock'. Re-insert the card back into the camera and power on the cam.Try some shots and see.
If this does not help, post another question in the comments box.
Sep 18, 2014 | Cameras
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
When i connect the camera to the computer, the pictures not showing up in the events or any other section. i want to store it on a flash drive and i cant get it store.
If the camera is recognized by your computer (as a Removeable USB device) and if you are using the Olympus [ib] software, the probable cause is Olympus [ib] software related. You can try to repair the created picture database using the Data Repair option in the camera menu (see the manual page 41).
An alternative is to use a SD / SDHC card to put your pictures on and transfer them using the card reader in the computer. It is also possible to transfer taken pictures from the cameras internal memory to a placed SD / SDHC card in the camera (see the manual page 41).
Nov 11, 2010 | Olympus SP800UZ Digital Camera
My samsung digimax s500 seems to be stuck on. I can't turn it off. If I open the battery door will I lose the pictures on the SD card?
No . The pictures that are stored on the SD card can be downloaded on to the PC as the images are stored on to the card and will not be deleted unless you do with the camera menu or the PC.
Once the SD card is taken out remove the battery and tryt o tap lightly on the camera with the hood down. It might release any jamming . repeat with the battery put in , with the power ON.
If not contact Samsung service.
Nov 01, 2010 | Samsung Digimax S500 Digital Camera
I can only take one picture. If I take another,
Try resetting the camera. Go into the setup menu and find "reset".
Sep 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
I took some pics on my laptop built in camera last night n tried this morning to save them to my sd card so i could look at them in my digital camera, but even tho they r stored on the card, i know this...
This is because camera will show these pictures with specific file name/ number.  You need to check camera taken picture file name/ number and change uploaded file name/ numbers as camera firmware generate it.  Please change picture file name according to camera taken picture.
let me know if further help required.
Jan 06, 2009 | Nikon COOLPIX L12 Digital Camera
Panasonic Lumix DMC-ZS3 Digital Camera Logo
262 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
