Question about Estate TEDX640JQ Electric Dryer
Dryer wont turn on at all----- we checked the power switch and it still wont work....can u give me a solution to my problem?
  • Estate Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
3 Suggested Answers
  • 58 Answers
SOURCE: dryer dont turn on
probably could be a PCB module
Posted on Mar 09, 2010
TheMobilian
  • 8220 Answers
SOURCE: dryer wont start dryer started smoking
That sounds to me like an air restriction has caused overheating.
The blower wheel on these dryers tends to start slipping with age. 528f0fa.jpgThe slipping makes the dryer over heat and cause the safety's to shut down quickly.1b3c53e.jpg 32276fa.jpgThis takes a lot longer for the clothes to dry. aff5565.jpgFinally the limit opens and kills the whole thing. To service it 9d5ebcf.jpg61b049c.jpg
Was this helpful?
Posted on Sep 13, 2010
My dryer has power just wont turn on
Might be a start capacitor (located along side the motor, average cost of part around $25.00 AU
To check if this is the case, remove rear belt sheet metal cover and switch on and select a few minutes on the timer control, then give the drum belt or drum (if you can ) and give it a turn in the direction of rotation.
If it starts to run this will tell you that it is a start capacitor.
If you have the ability you could bypass the door safety switch and spin the drum from the front to achieve the same test.
Good Luck
Apr 03, 2014 | Dryers
Maytag bravos electric dryer powers on but will not run no codes on it, just wont run
Check that door is fully closed. Or turn on dryer and manually press the door switch to see if that works. If not than it is that switch. A thermoswitch will also do that
Mar 30, 2014 | Dryers
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
I have a tumble dryer.
Sounds as if the door switch is the problem. This is normally a safety switch that stops the dryer when the door is opened.
Unplug the dryer.
Remove the door switch and check the switch condition with a continuity meter after removing the wires. Try turning the switch on and off....the meter should read power on and off when you do that.
You may have to remove the front of the dryer to get to the door switch.
Good luck,
I hope this helps
Oct 05, 2009 | Hotpoint Dryers
Estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Roper Dryer Won't Turn On
Quick check list starting with the most likely to the mostly likely NOT:
Fuse edfbadd.jpgmounted on the blowers housing this puppy is wired in with the door switch. If the lint in the dryer gets to blocking the exhaust then this puppy gets all hot and bothered and melts, causing the whole machine to come to a screeching halt just as if you have opened the dryer door. Clever ain't it? Clean out the lint and replace this fuse.
Dec 31, 2008 | Roper RES7646KQ Electric Dryer
TUMBLE DRYER WONT WORK
It will most probably be the door switch which is either sticking, give the door casing latch a gentle knock with the back of a screw driver, or is just broken. Try and get to the two wires at the switch and shorting them out i.e. linking out the switch. Make sure the dryer is UNPLUGGED when you do this.
Nov 28, 2008 | Dryers
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Estate TEDX640JQ Electric Dryer Logo
53 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
