Question about Amana NDE2335AY Electric Dryer
How do I take this apart to fix the heater element ?
  • 57 Answers
First unplug it. Then take a putty knife and about 1" from the corners feel for a spring catch. Just push in a little and lift on the top. Do this to both sides. Lid should lift up and lean back. Now see it there are a couple of screws holding the front face on. Should be close to the upper corners. Once you get the face off, go to the bottom of the machine look straight back on the left hand side you will see your heater. It is held on by 2 screws(1/4" head on them) about half way down the sides. Undo that and pull your heater out and replace.
Posted on Dec 29, 2010
My rannai propane heater makes a whistling sound.
Check the fan. Unplug the unit and remove the panel that houses the fan unit. Electrical cleaner can be sprayed onto the connection points of the nicad heater elements as well as the fan motor. It may be that one of the heating coils has a bad connection. Take apart and reassemble heating elements and connection points.
Jan 17, 2015 | Heating & Cooling
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Heater works fine but cold air
thermal fuse is usually the first to go check it for continuety
Nov 16, 2013 | Lasko 755320 Ceramic Electric Utility...
How do i get dryer apart to get to heating element model mde308 dayw
unplug dryer, move out from wall so you can get to the back. use a 1/4" nut driver and remove the rear panel. The heater element is on the bottom right. before replacing check for continuity. if the heater has continuity, check all of the other componets on the rear of the dryer. i would advise to check the small white thing with 2 wires connected.
Apr 29, 2012 | Maytag Dishwashers
I have a Lasko 5141 Ceramic Electric Heater, and when I turn it on, I smell burning and the heater makes a whining noise. I've tried vacuuming it, should I try again or is there another step I should take?
You have an excess amount of lint buildup inside the ceramic element, you need to take the unit apart to clean the element. The fan housing covers the backside of the element and blows the air forward, over a period of time lint builds up.
You need a qualified person to take it apart safely and clean it. It takes a Special Chinese Triangle Bit screwdriver to remove the 2 tamper proof screws from the back. Purchased mine at mcmastercarr.com
Triangle Bits
a7atriangles.png?ver=280340775941a14p1s.png?ver=23707593
These power bits have a 1/4" hex shank and are 2" long.
Size(A) EachTA180.070"5941A11$3.77TA200.083"5941A123.77TA230.090"5941A133.78TA270.100"5941A143.77
Feb 22, 2011 | Lasko 5141 Ceramic Electric Heater
No heat
Yes it is is a heater element problem. YOu have to access from the back panel. There are screws need to be removed. Once the panel is off, you can see the Blower and the heating element assembly. Take off the housing so you can replace the heater.
May 04, 2010 | Whirlpool WED8500S Electric Dryer
Lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Dec 09, 2008 | Lasko Ceramic Heater
Heating element
sure can. doesn't sound right that its" flaking apart". but its secured from under your machine with 2 nuts probly a $30 heater. be sure to turn off power first!!!!
Feb 22, 2008 | Maytag 24 in. MDB5600A Jetclean II...
How do you clean with a heating element?
it has to be taken apart and you need to blow compressed air through the front. dust particles get trapped between the fan and the heater element.
Oct 19, 2007 | DeLonghi DFH2550TB Compact Heater
Amana NDE2335AY Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
