Question about Maytag MEDC400V Dryer
The dryer turns on and heats up but the drum will not turn. the belt is on but I can pull it up about 6 inches. Why won't it work?
  • Maytag Master
  • 7,482 Answers
Your belt has slipped off of the idler pulley or the spring that puts tension on the idler pulley bracket is broken or came off of the bracket.
I will send you a link to a website to help you out on the routing of the belt.
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Posted on Dec 29, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
How do you get the heating element out of a dryer model GLER341ASO Serial X013305567
Disconnect power before working on this dryer.
Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
The heater is located behind the drum on the back wall. Disconnect the belt through the small opening at the rear of the dryer. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Lift drum about 1 inch straight up at rear...then pull whole drum forward while keeping lifted. This should expose the heater for checking.
Reverse process to re-assemble.
Oct 02, 2009 | Frigidaire Dryers
I need to know how to get to my heater coil on my dryer its a electrolux/fridgedaire mod fer311fso
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Sep 06, 2009 | Whirlpool Dryers
Dryer drum stopped when too wet of clothes were put in. Smells like burnt smell. Dryer turns on and heats. Looked for belt but can't locate in Whirlpool dryer I have front off
you have to raise up the top and the drum will just pull off the belt is only about a 1/2 inch wide like a piece of leather possibly laying on bottom under drum
Jul 03, 2009 | Dryers
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Maytag MEDC400V Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
