Question about Car Audio & Video
Car will not start. 89 olds 88 replaced fuel pump coil and ignition control modular. still does not get fire.
  • 3 Answers
Double check that you get pressure and flow, maybe pump relay. also check the crank and cam sensors along with the mass airflow. some vehicles will not run with faulty airflow sensor. Have you checked for any trouble codes?
Posted on Jul 11, 2008
My 89 f150 run for about a mile/ mile and a half then sputters and dies. Takes 10-20 minutes to restart then repeats. Is lack of grease on icm possible reason?
It would usually take longer than that on the ignition control module may need to look into a fuel filter is clogged or if the high pressure pump is not working
Feb 05, 2017 | Cars & Trucks
My 93 taurus turns over but no start the CCRM buzzes when the key is on and I have constant power to the coil wire when not cranking changed CCRM no help used too if I hit CCRM it would stop buzzing
Ignition control module or PCM problem or pick up coil ! The CCRM - constant control relay module just has control relays for the fuel pump , cooling fans , A/C clutch coil control , PCM power . Nothing that would make the coil fire continuosly . I would check out videos on youtube test ford ignition system's ScannerDanner gets his but kicked by an 88 150 EEC IV Ignition
Dec 12, 2016 | 1993 Ford Taurus
89 ford F 150 . Lost fire to fuel pump and spark to plugs at the same time
There is a bad connection . Could be a loose fuse. loose wire , faulty circuit breaker . or ignition switch. If the fault is still there start at the ignition switch hot wire should be 12 volts, turn on ignition should be 12 volts on + terminal of ignition coil and 12 volts at fuel pump. if not repair as required .
Nov 29, 2014 | Cars & Trucks
93 olds 88 after start runs 1 to 2 minutes then dies. in no start condition voltage to crank sensor is 2 to 2.5 volts. replaced icm does same thing what else could cause voltage to drop?
Check if the car has an ignition coil. That thing has caused me no end of anguish! After all my diagnosing, checking and almost giving up, the ignition coil was the culprit. Sometimes my car would start and then just shut off. Replacing it should be an option before taking it to a mechanic. If you don\'t have an ignition coil, something is overheating and good luck with that. Sorry.
Jul 06, 2014 | Ignition System for Oldsmobile 88
My 88 plymouth reliant has just stopped working. I have changed the spark plugs, wires, fuel pump, and fuel pump relay. i've also changed the fuel filter twice now. i've checked to see if it has spark and...
Check the ignition timing is correct. I see that you have changed the wires so I suggest that you recheck the firing order for the plugs as it is easy to get it wrong when replacing the leads.
Oct 23, 2013 | 1988 Plymouth Reliant
1999 olds 88 will not start. The battery and the starter are good. i turn the key the lights all turn on but the car will not start
Sounds like your not getting fire from your coil. This supplys the fire to your plugs to ignite your fuel in your heads. Good luck to you.
Apr 04, 2011 | Oldsmobile Delta 88 Cars & Trucks
My olds 1992 88 stopped running. changed the fuel filter and drained all of the old fuel (which wasuper rusty and contaminated). the car seems to want to start now but wont. i have been told to change the...
have you got a good spark- take out a plug and lay it plugged into the lead on top of the engine so the tip is earthed (touching the engine) and crank it over - DO NOT TOUCH THE PLUG WHILST CRANKING AS IT GENERATES MASSIVE ELECTRICAL VOLTAGE..............
if it sparks its probably a fuel problem still and not ignition/electrical.
Sep 18, 2017 | 1992 Oldsmobile 88
1995 olds 88 3.8 L. Sometimes won,t start.Cranks and immediatly dies on 1 to 10 attempts.Once starts ,runs fine. already replaced crank pos. sensor. Can hear fuel pump prime up when key is on. No check...
check the ignition control module wires are shorting out? Try the wiggle test next time no start. wiggle the wires and see if it starts.This is a factory mechanic approved test procedure.
Aug 07, 2017 | Oldsmobile Delta 88 Cars & Trucks
2.8 engine Would start when cool, but stall after
89 cierra? It should be DIS ignition so you can't have the timing too high. You said it has fuel and spark. Fuel pressure and injection pulse. Does it try to start if you spray carb cleaner into it?
Jun 03, 2010 | 1989 Oldsmobile Cutlass Ciera
Firing diagram for a 87 olds delta 88 3.8
1987 Oldsmobile Delta 88
3.8 liter V-6 VIN "3" Identifying Ignition Types I and II
On Type II coil packs, the coils can be replaced separately and the ignition wires are all on the same side of the coil pack.
With Type I Ignition
With Type II Ignition
Apr 02, 2009 | 1987 Oldsmobile Delta 88
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
