Question about Dryers
My beko dryer condenser keeps saying that the water tank is full when it is not?
SOURCE: zanussi tc7103w condenser dryer-water tank
I had this problem. If you look at the valve on the plastic water tank, you will see that those parts are the same. They fit inside the tumble dryer to shut off the water from flowing onto the floor when the water tank is removed. The white hollow cylinders in the tumble dryer and the water tank push each other open. If you study the water valve on the tank you will see how it is put together. It is all held in place by a little 9mm O ring at the back of the valve. The ring gets tired after a while and pops off. The valve then falls apart and you find the cylinder and spring on the floor and the O ring still inside the dryer. I bought an O ring kit and reassembled the valve inside the dryer using a new ring. You will have to pull the dryer out, turn it upside down and remove the floor to do this
Posted on Jan 19, 2011
  • 139 Answers
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
SOURCE: 8kg Candy Condenser dryer keeps stopping and
Hi Andrew, Nothing I found on-line worked. So tonight I had a good look. Inside the machine at the back of where the water caddy fits there's a reservoir. This was full but oddly the water caddy was empty. On the caddy there's a spout with a valve, inside it was fine dark fluff which was being compressed every time the caddy was reinserted. I picked this out with a little stick. I also, and this may not be necessary, removed the valve socket that the caddy valve goes into. It's attached by three screws to the bottom of the machine. This was also clogged with the same sort of fluff. Both blockages were stopping water passing freely into the caddy and so water built up in the reservoir tripping the empty light. Something to check for. Anyway mine works fine now and thought I'd share. Best regards, Ed
Posted on May 13, 2010
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Zanussi condenser dryers
    It can be mechanical or electrical malfunction. I would check tank microswitch, float and lever.
    Below is explained how the condensate drainage system works and that will facilitate fault detection.
    The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
    Dado
    Aug 10, 2014 | Zanussi Dryers
    Beko dryer
    i have had this problem and its usually the pc board is faulty
    Mar 28, 2014 | Dryers
    Beko condenser dryer
    check dampness senser may still have lint trapped around it
    also poss. stuck button on control board
    Dec 06, 2013 | Dryers
    My beko dryer keeps saying water tank full when it is empty!
    empty the small reservoir around the back
    there's a single screw to take out and siphon the water out with a small bore pipe I used two drinking straws taped together
    you will see the float go down and turn the switch off
    Mar 21, 2012 | Dryers
    I have a two year old Bosch Ecologixx 7 Tumble Dryer (WTW84560GB/02) whose condensation compartment full indicator is being activated increasingly early, to the point where I am needing to empty the...
    I had exactly the same problem and got it fixed by the Bosch repair service today.
    The culprit is that in certain areas there may be algae in the air that thrive to grow in the main water reservoir and clog up the water pump that fills the condensation compartment.
    (note: There are two water tanks in the Ecologixx 7 - one user serviceable condenser tank up top and the non-user serviceable main water reservoir sealed inside the machine)
    This is main water reservoir is located sealed under the water pump under the tumble dryer drum.
    Dismantling instructions: 1. remove the top of the tumble dryer first (two screws at the back 2. remove the right side panel with another few screws (looking from the front) 3. disengage the multi-tooth elastic band by twisting the spring loaded roller at the bottom).
    After this you have access to the water pump and the Styrofoam float that triggers the empty condenser tank warning.
    If the pump is entirely clogged you might need to replace it and the float.
    Then clean the bottom water reservoir from the algae infested water with a pump+hose and a bottle washing brush and circulate clean water through the machine (re-engage the elastic band before running the engine) with the Warm-program.
    To kill the algae you need to run about 250ml of clear raw vinegar through the pump system by running the machine in the Warm program for 10min and then rinse the excess vinegar out by putting about half a condenser tank of warm water into the machine and running the Warm-programme for 30min. (this will release the clean water into the condenser unit for the self-cleaning function and then pump it back up into the condenser water tank and dilute and circulate the raw vinegar out of the machine).
    You should also do a vinegar sanitization run before all extended periods of disuse of the machine by pouring 250ml of vinegar into the large round hole under the top condenser tank (this is where the condensed water is poured for the self-cleaning run).
    Run the Warm-program without the condenser tank in place until you can verify visually that the pump is circulating the vinegar through the hose in the top left back corner of the condenser tank opening (there is a overflow drain at the back so everything coming up goes promptly back down into the main reservoir (small hole in the back corner bottom).
    Then place the condenser water tank half full with hot water (not boiling) and let the Warm-programme run for 30min to dilute and circulate the vinegar-water solution out of the machine back into the condenser reservoir.
    Feb 05, 2011 | Dryers
    Zanussi Tumble Dryer
    Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
    Dec 30, 2007 | Dryers
    Dryers Logo
    903 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
