I have a Hotpoint Ultima WT960 7kg load capacity but when i put the programme on to was the drum does not move? Please advise what could be the problem
  • wendywoo481 Jul 07, 2008
    Yes the motor does run it pumpss out and refils but just does not move. thanks for the solution
    regards
  • Philip Beardmore
    Philip Beardmore May 11, 2010
    Does the machine's motor run (listen closely) and the program continue, (pump out and refill)?
    If so, it may be the belt.
    Problem Solver:
  • 10 Answers
Don't mention it !
I had to reply, or I keep getting a reminder in my mail !
Posted on Jul 07, 2008
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Wf865 drum won't turn in programme
have you checked the motor brushes there are 2 of them they are located on each side of the motor you will have to take the motor off and you will see them at the back of the motor undo the 2 screws on each one and take out the carbons should be 25m long and shinny and spring in and out freely I can supply new ones if you need them
Sep 27, 2012 | Hotpoint Ultima WF865 Front Load Washer
Leaking hotpoint ultima washing machine
Hotpoint ultima wt965 washing machine This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 16, 2012 | Hotpoint Washing Machines
I have a Hotpoint WMD 960 Ultima. When I remove the washing after a cycle, the clothes are covered in dirty marks. can you tell me if this is something you can advise me about?
Look within the drum and observe if there is any dirt on it. Also check the quality of water. Check if there is any dirt /grease from the drum bearings due to failure of the bearings/seals.
Finally have the machine cleaned using good detergent cleaner , please check the link below for some tips:
http://www.espares.co.uk/parts/cleaning-products/dishwasher-cleaning/p/1423
Jul 09, 2011 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
