Question about Dometic Refrigerators
Dometic rv frig; won't ignite on gas. Works on electricity.
    Top Expert:
  • Dometic Master
  • 5,673 Answers
Ignitor or burner tube dirty
Posted on Oct 14, 2017
SOURCE: I have a Dometic rm2807
Check out this site www.rvcoolingunit.net
Posted on Jul 28, 2008
  • 4793 Answers
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Posted on Feb 09, 2010
  • 332 Answers
SOURCE: Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Posted on Mar 08, 2010
  • 332 Answers
SOURCE: my dometic rv refrig is not working on electric
Check to make sure your getting 120 volts to the unit
Breaker tripped ?
Posted on Mar 31, 2010
  • 905 Answers
SOURCE: RV frig: won't run efficiently on gas
Hi Mitch,
Couple things to check, but they are going to take some time to do them.
First, check the burner area, and especially the burner itself. It should be free of debris, and have a nice blue flame when it is lit. The flame should be centered in the burner area.
Second, and this requires going on top of your coach, is to check your burner tube (after fridge has been turned off for a while). Open the fridge vent on the roof, and you should be able to reach down and remove the flue cap (if present). You are looking for a little piece of wire that is hooked on the side of the chimney. Pull this wire, and there should be a curved metal strip attached at the bottom. Look for insect activity, as well as the bottom edge being rough. The bottom edge should be smooth. Using a flashlight, you might be able to see down the chimney for debris that might have built up. Run a long thing brush down the chimney to clean it out. Remove the debris that has fallen into the burner area.
You also need to check your orifice to see if it is blocked, particularly if the flame appears to be weak. You can get an operators manual from bryantrv.com under the owners manual section.
By The Way, your fridge is on the recall list. You need to contact Dometic to check its status (you will need serial #) if you haven't done so already. If your fridge has the recall kit installed, did the gas operation possibly start after the kit was installed?
Posted on Jul 18, 2010
110 volts works but 12 volt does nothing, checked voltage 13.6 v. Any suggestions. Thanks.
RV Refrigerator Stop Working? - RVing - Fun Times Guide
rv-roadtrips.thefuntimesguide.com/2009/09/rv_refrigerator.php
If your refrigerator works on gas, but won't work on electric, you may have a burned out.... Cirtis, We are camping in Montana and our dometic refrigerator decided to stop ......Won't know until you can confirm you have proper voltage to the fridge. ... If you have confirmed both 12 vdc and 110 vac power at the fridge, I would ...
[PDF]Dometic Manual Refrigerator Diagnostic Service Manual
www.nationalserroscotty.org/resources/dometic-service-manual.pdf
Dometic Manual Refrigerators. ... 110 Volt Plug. 2. .... This is Dometic's Manual Refrigeration Diagnosis and Troubleshooting program. In this ... we will discuss the way an absorption cooling unit operates, and the ... gas, 120 volts AC and 12 volts DC .....In this condition we are still boiling ammonia but have no hydrogen for.
Dometic Fridge problems - RV mechanic
Dec 28, 2015 | Dometic CF-050DC CF-50 Waeco CoolFreeze...
We have a dometic frig in our RV that runs on either electric or gas. Can I run it on gas while driving to the campground or do I just turn it off until we arrive?
The dometic is designed to run down the road in the gas mode, but NEVER fill you LP tank with you unit switched on, in either the gas or AC mode. Make sure you shut everything down before filling the tank!
http://67.238.126.140/pdf/3309661.001.pdf
Aug 13, 2011 | Dometic NDR 1062 Refrigerator
Action 1: My RM2652 runs well on auto mode when its indicator's light is lit. Auto mode is an electric mode, right? Action 2: When I press on the "gas" button, the indicator's light next to the "auto"...
Auto mode is electric 1st then gas. If no 110v is available it tries to light the gas. Do you have gas & is it turned on? You should hear a clicking from the back of the frig. Make sure the air is purged out of the system by lighting your range and let the burners come on for 30 sec or so. You might have to cycle the frig on & off a couple of times after you purge the air. Set the button to "gas only".
Apr 01, 2010 | Dometic RM2652 Refrigerator
Feb 08, 2010 | Dometic RM2652 Refrigerator
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
124 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
