Question about KitchenAid KSRP25FN Side by Side Refrigerator
KSRP25FNSS00 ice maker stopped working. I've unplugged the fridge for half a day to clean plus in case any build up of ice on parts (water inlet, ice maker, etc). Turned it back on and hear water into tray, waited for a day and still no ice in bucket. LED seems to be working correctly as showing steady light when flapper is pushed. Should i go ahead and change the ice maker module?
  • 1314 Answers
SOURCE: Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Jan 19, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
SOURCE: kitchenaid removing icemaker
I am having the same problem but the freezer has been turned off for sometime (no one living there until now) so a frozen line is not the issue for me. The ice maker control blink orange whether it is turned on or off...what do you think?
Posted on Jun 17, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
I have an LG fridge display giving me ER F1 code. i can unplug the fridge and plug it back in and the display resets for about 2 minutes and the the code comes back?
The ER 1F code usually means that there is a problem with the ice compartment fan, the ice maker motor or one of the control boards (the one for the ice maker or the main control unit). You can try resetting the refrigerator by leaving it unplugged for a day. Next check for ice build up on the fan that is blocking it from turning. Usually, if the fan hasn't been turning, you will have to at minimum replace the motor. It will burn out trying to force the fan to turn.
Sears Parts Direct has a diagram of the LFX23961SW case parts here: http://www.searspartsdirect.com/lg-refrigerator-parts/model-LFX23961SW/3204/0161000/K0810254/00001.html . The fan motor is part 405G.
I hope this helps.
Apr 15, 2015 | LG LFX23961SW French Door Refrigerator,...
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
B20cs50sns bosch ice maker stopped making ice
sounds like you have no water coming in...pull the line..make sure u got water..vacuum out the back fins and bottom so theres no dust or build up on the cooling fins..clean the inside..plug it in and try it..
Jan 08, 2014 | Bosch Refrigerators
GE GSH25JSTASS water and ice maker not working
I had the same problem.
I found that the inlet tube was frozen over as was the drain on the reservoir that fills the ice tray. Clearing the ice build up did not fix the problem. I also noticed that the ice maker seemed to be half filled.
I found that the valve is working by wiring a line cord directly to the valve. This caused the ice maker to fill (overfill actually since there was no sensor to turn it off).
Allowing the ice maker to cycle now that if was filled has solved the problem. The only thing I can think of was a power failure or manually turning off the ice maker while it was filling.
If you are capable of manually testing the inlet valve as above and it does not fill the ice maker, then the valve is defective. Cost is below $50 as this posting. Part number is AP3192626.
If the valve works and it is not a partial fill problem as was mine, then the problem is with the main circuit board on the back of the fridge. The part number is AP4436216 and ranges from $122to $140 as of this posting date.
May 07, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
Hello: I hope that you can help. The ice maker on this model (et21dk) is spitting out water as well as cubes. As a result, my tray is a frozen lake of cubes. How do I fix this? Thanks. Ben My...
Ben open your freezer section and reach to the very back and top of your ice maker where the water inlet tube is located. Use your finger and check for ice formation near the end of the water inlet tube where the ice maker plastic water channel is.
If there is ice in that area unplug your unit and use a hair dryer to thaw out that area. Try not to keep the hot air blowing in the same place when your using the hair dryer so as not to melt any plastics. This some times just happens all by it self that there is ice formation in the water inlet area. While the unit is unplugged use the hair dryer to free your ice tray also.
Once you restart the unit it can take longer than usual before you have ice cubes again. Not more than 1 day. If you continue to have ice formation in your freezer section then your ice maker has and internal failure of either the water control micro switch or actuation lever. The ice maker can be repaired but the cost will be about 60 percent of the cost of a new icemaker..
Jan 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
May 30, 2009 | GE Profile PSW26P Stainless Steel Side by...
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
KitchenAid KSRP25FN Side by Side Refrigerator Logo
217 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
