Question about Samsung Televison & Video
Samsung dlp HLN437w (GREEN lamp and RED temp)-same time flashing. lamp and housing has already been replaced whats next?
  • Samsung Master
  • 5,138 Answers
If the Ballast board is not working Lamp will not come on,if the Lamp Fan is defective Lamp will not Light or stay on.
Go to Encompass Parts Distribution and Look up your Model#
they have free service manual for this TV.
Posted on Dec 29, 2010
  • 2 more comments
  • Bryan Bonsack Dec 29, 2010
    I used a volt meter to check voltage on red wires connecting to housing/lamp i got power going through ballast can it still be a bad ballast?
  • ladywinn
    ladywinn Dec 29, 2010
    Before you replaced the Lamp,when TV first went out did you noticed when you tried to turn set on if their was an Ark coming from the Spark Gap on the Ballast Board? Spark Gap Looks Like
    a Big White Blue strips on it Diode.
    When Lamp is defective Ballast Board will Ark at the Spark Gap,if it doesnt then the Ballast Board is bad.
  • Bryan Bonsack Dec 30, 2010
    what is the blue switch for located behind back side panel on lamp side. what ever it is i held it up in the up position and the lamp fired up everything now work unless the switch is let go.
  • ladywinn
    ladywinn Dec 30, 2010
    Their is a safty switch mounted on chassis fame that has to be engaed before set will firer
    have you put back on TV and then try it?Back is what engages the Swicth so set will turn on.
    Is this the switch you are talking about?
Samsung DLP 72" HL72A650C1F keeps turning off amd on
Did you buy the original lamp?
If the problem is related to the lamp door switch, you will get a different error instead of lamp LED.
Do you hear the color wheel spinning?
Again, if it's a color wheel problem the error will be different!
My good guess is the lamp but, it could be the ballast or both.
Best of luck
www.aaatvservice.com
May 08, 2012 | Samsung SELECT HL72A650C1F Rear Projection...
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp 4266wx problem
Greetings,
Now the projector is having a problem with the lamp as the LED indicator displays.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 07, 2008 | Televison & Video
I have a Samsung HLN437W 43" wide screen HDTV Monitor TV with DLP Technology. The tv picture will not come on. The three light in the front of the tv are all flashing (1 red and 2 green). I live in...
All you need is a new lamp thats what the 3 lights blinking is indicating. Very easy to do this yourself. Just order a new lamp and let me know when it arrives and I will explain how to change it. Very easy takes about 5 minutes.
Mar 29, 2008 | Televison & Video
Televison & Video Logo
193 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
