Question about GE Profile WPRE6100G Top Load Washer
Basket won't spin or agitate. What might be the problem?
  • 21 Answers
Check to see if the drive belt is broken
Posted on Dec 28, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
Kenmore 70 series won't always spin. It agitates but does not always spin. Lid switch, tranny, what?
It could be lid switch. It could be spin basket drive as well. Will you ewasher agitate with the lid up? Does the washer motor run but the tub doesn't spin? If the motor runs in the spin cycle with the lid down, it is not the lid switch.
The spin basket drive is driven by the transmission.
Let me knwo if I can help further. Thanks
Vic
May 15, 2009 | Washing Machines
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
50 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
