Question about Canon PIXMA MP780 All-In-One InkJet Printer
My MP780 is displaying wrong cartridge, I tried to use the ok button, and tried to turn the printer off and then back on again and the error message won't clear, I even went so far as to take all the cartridges out of the printer and still won't clear the wrong cartridge message. is there anything else I can do?
    President:
  • 228 Answers
I had the same problem on my pixma mp780. I cleaned the printer head. it worked for about a year, but then i had to replace the printer head. after you clean or replace it reboot it.
Posted on Dec 30, 2010
Cant print. error message wrong cartridge, cant change
try this,
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Mar 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Error: ''Wrong Cartridge'' when no new cartridge has been installed
It is probably one of the cartridges. Usually, when the message "wrong cartridge" appears, the cartridge is faulty.
Apr 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cartridge Jammed
Try removing the print cartridge and then insert it again this should clear the problem.
Feb 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Memory error
Just do 2 steps:
1. Press Stop.
2. If the display highlight "Resume". Press the OK (Check Button).
The display will tell you that a Non-HP Cartridge is installed and Economode is Disabled.
At least, you can now print. The display will show back again to "Ready".
Jul 23, 2008 | HP LaserJet 2420 Printer
"Wrong Cartridges" Error HP C5180 now Failed ink system.
Please perform the following steps:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button
Display should say “Support” and display the FW rev (something like R0616R)
Now, perform the following instructions:
1. Press and release the right arrow button until the displaysays “System Configuration Menu” 2. Press and release the “OK” button.3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.5. Display should say “Hardware failure status: Clear. Press OK to clear”.6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. 11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.13. If the error is still there, or reoccurs replace the unit.
Jul 13, 2008 | HP Photosmart C5180 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Here is what I did and it now works just fine.I turned off the printer and unplugged the power cord, and unplugged it from my computer. I then removed all the ink cartriges and removed the print Head I got some rubbing alcohol put it on some toilet paper and wiped down the back and bottom of the print head.Plugged everything back in and It now works better then ever.
Feb 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
"Put in cartridge" error message
Issue: ERROR LCD: PUT IN CARTRIDGE
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
849 people viewed this question
old marine
old marine
