Question about Refrigerators
Everything works fine for this refrigerator except that when you press ICE on the control panel and insert your glass into the discharge area, the ice maker paddle (auger) does not turn to extract ice from the ice bin into your glass. The ice is not frozen into a big lump in the bin and is eliminated as a cause for this problem.
Does the auger sound like it is turning ? If it sounds like it is turning there maybe a drive gear that is missing drive teeth or a shear pin has sheared preventing the auger from turning and despencing the ice
Posted on Dec 29, 2010
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Control panel failure
Have you tried unplugging and plugging the fridge back in? This may reset the control baoard.
Apr 13, 2014 | Refrigerators
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
The ice maker works fine but we can no longer dispense ice from the door. No sound, nothing. Water dispenser works fine though.
There is a micro switch behind the panel above the dispenser lever. It's the switch that the leaver presses on when you push a glass into it to fill with water. Pop the panel off and you will see the little black switch I'm refering to.
Aug 15, 2009 | Whirlpool GD5SHAX Side by Side...
Ice dispenser does not work and water dispenser works rarely.
the solenoid fell off, where does it go, it must regulate crush ice vs cubed ice. everything works except this
Jul 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
