Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Replaced single digit temp control on side by side due to surge unit started cooling but stopped and #4 on fridge side of control is flashing . was set at 6 on control display .
  • 639 Answers
WHAT'S YOUR QUESTION????????????????????
Posted on Aug 28, 2008
Samsung SRS583DW Fridge / Freezer not freezing
The unit has a built in defrost cycle that is controlled by the main board. You need to replace that board.
Nov 20, 2013 | Samsung Refrigerators
Refrigerator temp erratic
you will have to replace your thermostat of the fridge
you can find it near the light inside the unit
Sep 17, 2008 | Samsung RS2534 Side by Side Refrigerator
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
I got a frigidaire phs66ejsb0 and in the digital dial of fresh food temp the error code 4 is flashing what could it be
As far as i know this means the damper failed the start up test which is producing the error code 4. It could mean the replacement of a circuit board that controls the temperature as the H2O filter may have leaked and shorted it out.
You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature
control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and
hold it for three seconds.
Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops.
To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds and see if that resolves the problem.
If not then you will need to contact Frigidaire themselves for advice on how to resolve this problem or to have and engineer come and take a look at it for you.
(United States)
1-800-944-9044
(Canada)
1-800-668-4606
Good luck.
Jun 26, 2010 | Frigidaire FRS26H5AS Side by Side...
Freezer is cooling fine, but fridge is not cooling properly
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 12, 2010 | Frigidaire FRS6R4E Side by Side...
The digital display on my rs2555sl Samsung stopped working and the fridge and freezer are not cooling. The fridge is only 4 years old. what could the problem be?
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Jan 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
Stops cooling (fridge and freezer) then starts again
if turning the temp control up and then back down turns it back down, you might start with the thermostat. unless you have a local shop you like i recommend. http://www.appliancepartspros.com/partsearch/
Aug 17, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
