Question about Dayton Gas Furnace Heater
I have a dayton hanging furnace that after a few minutes the fan stops and burner keeps burning then a few minutes later the fan starts again and keeps repeating this cycle. model 3E845. thanks.
  • Dayton Master
  • 8,220 Answers
On the side of the heat exchanger is a fan Klixon that turns that motor on when the temp exceed 110f on the side of the heater. maybe that thang is going out or your fan motor needs oiling and is cutting out on overload. Next to the fan klixon is usually a limit. Both look the same. The fan klixon will have a marking stamped into the metal such as F-120 the limit will have L-240.
Posted on Dec 28, 2010
Dg606i have afurnace that the burner comes on and burns then shuts off a minute later the fan comes and blows for minute or so then shuts and the burner comes again burns for 3 or4 minutes shuts off then...
Your Furnace is short cycling...cutting out too soon. I would call for service on this one. If it has a flame sensor and you know where it is, clean or replace the sensor. If there is a air/sail switch, make sure it is free to float/swing.
Oct 17, 2013 | Dryers
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
I have a Dayton Furnace Serial# swglm033942 and need some information; My furnace is installed in the attic and sometimes it will not blow hot air. I have tried to start it and the burners start up, but...
Please have this checked out by a technician. If there is a crack in the heat exchanger it could do just as you described. The blower blows air into the combustion chamber and blows out the burners.
Jan 07, 2011 | Dayton Gas Furnace Heater
Our furnace seems to run on idle constantly . we are using more oil but not electric if i tap on the box it stops but starts again a few minutes later??
We need to get a few details cleared up:
Is it the Furnace (Oil burner) that is running, (on idle you called it..)
or is it the FAN that is running?
What are you tapping, that shuts off what?
Is the fan that blows the air around the home shutting off, or the burner?
(When the burner is running, there is a loud roar!-- the fan should be much quieter..)
If it is the fan that is running,-- I might ask, is the air coming from the registers too cold?-- for with the fan running, you are getting all the heat from the oil that was burned. But naturally, you don't want it to be uncomfortable.. So-- you can open the cover on that Fan control switch, and raise the temperature at which the fan turns ON and OFF..
Let us know what you find.
Mack B
Dec 28, 2010 | Heating & Cooling
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
455 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
