Question about Maytag MFD2560HE Bottom Freezer Refrigerator
Both the ice maker and water dispenser have stopped working
SolutionGuy
  • 331 Answers
SOURCE: ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Posted on Aug 01, 2007
the dr
  • 447 Answers
SOURCE: ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
Posted on Oct 05, 2007
SOURCE: Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Posted on Sep 08, 2008
SOURCE: Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Posted on Jun 05, 2009
woodchuck789
  • 4066 Answers
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Aug 29, 2009
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
It can be faulty water fill valve or the water line is clogged or its issue with water dispenser itself and needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 26, 2012 | Samsung RF26XAEWP
Water dispenser not working on Daewoo DRS31PSM fridge freezer
Get the water valve checked.
May be its not letting the water to pass through the line.or its blocked auger.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water dispenser & ice dispenser stopped working
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
The water line is clogged or water dispenser valve is blocked.Click this link below for troubleshooting:---
This will help. Thanks. Helpmech.
Oct 31, 2011 | Refrigerators
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
Maytag MFD2560HE Bottom Freezer Refrigerator Logo
16 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
