Question about HP Office Equipment & Supplies
Fm previous satisfied customer -- Re 10+ y.o. home HP4L. Am getting numerous paper feed probs. Will only print a page or two before red light and page sticks out of last slot. Have to open back, top, tray, pull power to again feed. Have in past fed "cleaner sheets" with some success. Would like alternative (thoro cleaning w/alcohol-soap?). HP has roller kits, etc. ???
  • mobacc Jan 03, 2011
    Yes. Finally found the HP4L service manual and coordinated the contents with pages. Still would like a pictorial on cleaning and replacing rollers. A thorough air blowout seemed to do the job.
    Genius:
  • HP Master
  • 1,739 Answers
At 10 years old you may be right that there is some wear showing up. Have you changed the type of paper you have been using?
You might find the information on page 28 of the Print Media Specification Guide to be most useful in troubleshooting this issue and making sure you are not using incorrect print media; page 29 lists cause and solutions to frequent paper jams:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
I am also including a couple of other links that may be of assistance.
HP LaserJet 4L Printers - Paper Jams: Possible Causes and Removal Instructions
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=25486&prodTypeId=18972&prodSeriesId=25486&objectID=bpl01333
HP Parts:
http://h20141.www2.hp.com/hpparts/Default.aspx?mscssid=993012CB8045463B90EDBCC07B9EF136
Trust this is helpful.
Posted on Dec 29, 2010
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
HP4L prints all balck page
Try reseating the print cartridge if this does not work try a new print cartridge the problem seams like your primary charge failure.
If you require more help please get back to me
Thank You
Mar 11, 2008 | HP LaserJet 4L Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
49 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
