Bought kerosene heater in middle of November and seem to have a wick issue. It will not burn properly and makes me wonder if wick was place in upside down. Can I fix it myself?
    Novelist:
    Champion:
  • 224 Answers
Trust me you can not install a wick upside down, the bottom of a wick is like an old mop. It has loose wove string and knots, it's job is to **** up fuel. Things to remember about wicks are, they need cleaned some times, I use an old tooth brush and gently brush the wick with it set down low so it does not get damaged. A wick must also sit and soak for at least a half hour before attempting to light it. A good practice to get in to is about every fourth tank of fuel let the heater burn out, this also cleans out the wick and burns off all of the impurities from dirty fuel. Yes you can check your wick but the entire heater does have to be tore down and you should do it only with an empty tank of fuel. This takes time , patience, and a little mechanical know how. When burning out a heater please remove it from your house and let it burn the smell is terrible, if you do this in your house it will smell like a semi truck is running in it.
Posted on Dec 29, 2010
Black smoke coming kerosene
hi dear,
First of all make sure that the heater is filled with K-1 Kerosene. Other fuel, such as gasoline, home heating oil, etc. do not burn hot, causing the heater to burn out of control. NEVER USE GASOLINE or any other fuel described as flammable. If there is any question about the fuel in your heater it is best to drain it and replace the wick and start with fresh K-1 Kerosene. If you are sure of your kerosene and your heater is giving off sooty black smoke it is a sign that the fuel/air mix is off. Make sure your heater is not in a draft. Too much air can create a very high flame condition. Avoid placing the heater in drafty areas or under a ceiling fan. Make sure the burner chimney is seated correctly. If the burner chimney didn't seat into place correctly after lighting you may be getting a very high flame on one side. If it's a high orange flame all the way around try rolling the wick adjuster knob down within the adjustment range - the wick may just be raised too high. If these things do not fix the problem wait until the heater is cool and inspect the burner cylinder. If there are any holes plugged with soot it needs to be cleaned, or if it's dented or buckled it needs to be replaced. After you have checked the fuel and burner you should check to make sure the wick is installed at the correct height. Refer to the owner's manual for exact wick height. If the wick is installed correctly and there is no other obvious defect it is best to take the heater to a service center to determine the cause. Our Find a Retailer tool can be used to help find a servicing center.
Jan 04, 2014 | Corona 23-DK Compact Heater
WILL NOT START BURNING. REPLACED BATTERIES, GOOD SPARK. CLEANED. NO FIRE
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Dec 10, 2010 | Northern Tool 10,600 BTU Radiant Kerosene...
I have a 23-dk corona kerosene heater. it was smoking so i replaced the wick. after replacing the wick it still smokes heavy. how do i fix the problem.
Check all airvents into conbustion chamber. Make shure they are all clear of blockage. The heater needs air to burn fule properly. Check wick adjustment it may have to much wick.
Sep 03, 2010 | Corona 23-DK Compact Heater
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Dec 16, 2009 | Heating & Cooling
Dyna-glo kerosene heater (rmc-55-r7 )
wicks won't light for usually one of 2 reasons. water in the kerosene, which means a new wick and new fuel. or build-up on the wick. check to see if the wick is hard. your wick should be soft. burning out the heater until all fuel is used either by running down all the fuel in the unit or removing the fuel can and lighting to burn off all fuel in the bottom will prevent the wick from getting hard.
Mar 09, 2008 | Heating & Cooling
Kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
