Question about SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter
I broke off the on/off switch on a syma s107 helicopter
5 Suggested Answers
SOURCE: syma s107 take off problem
The blades could be on up-side-down or The battery may not be holding enough of a charge anymore. If it's the battery, check out these Syma S107 Battery replacement instructions.
Posted on Sep 16, 2010
SOURCE: Hi, My Syma S107 has been
It requires the rear rotor to have front/backwards movement.
Posted on Mar 19, 2011
  • 10 Answers
SOURCE: The tail rotor on my
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
Posted on Apr 09, 2011
SOURCE: SYMA S107 Helicopter. Advertised as 3
You're both confused. "channel" does not refer to how many different controller positions. In helicopter-speak, "channels" are how many different flight controls you have.
1) Throttle up/down, provides lift (left joystick)
2) Tail rotor up/down, tilts back end of helicopter, providing fwd/backward movement (vertical axis of right joystick)
3) Coaxial main rotor differential, by letting one of the two main blades spin at a slightly different rate than the other, helicopter can turn left/right (horizontal axis of right joystick)
Notice that sometimes these birds are labelled as "3.5 channel" the .5 of a channel refers to the trim control.
Regarding the ABC rocker switch. Most s107 helicopters have only two positions, meaning that only two helicopters can be used near each other and be controlled independently. (as many as you want can be controlled using one controller, there's youtube clips of a guy flying like 10 of these at once with one controller) There is one Syma s107 that I've found, available from Amazon (with Amazon, Inc. as the vendor, NOT a third party seller) that actually has 3 positions on the ABC rocker switch, they can be easily identified by the motors. Most s107s have two motors, one with a black top, and one with a white top. The "amazon" s107 has a pink topped motor and a green one. It's also about 50% faster and more agile than the standard s107.
I have 4 by the way.... 3 'normal' and 1 'super' they're all great but if I ever buy another it'll be the pink and green for sure.
So yeah, the ABC switch and the "3 channel" or "3.5 channel" are two different things.
Hope this clears up the confusion.
r
Posted on Sep 13, 2011
My syma s107 isnt responding to my controler
change the batteries in remote controller,,sure for charging indication in flying kit s107,,otherwise describe the fault completely to me
Jan 19, 2015 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 bottom rotors won't turn. What is the fix?
Probably just the cog on the motor not meshing with the main shaft gear.
Kind regards, Julian
rccontrolfreak.co.uk
Aug 07, 2012 | SYMA Toys industrial New Syma S107 Radio...
Syma s107 hit a dangling string that got tied up instantly and seized the rotors. now lights up but blades don't spin when throttled. What can I do besides replace the helicopter?
I was flying my syma s800g and hit the ceiling fan chain. When I attempted to fly it would spin and fall over. The problem was I broke the two small plastic pins on the top rotor holder. Ordered a new top rotor and flies fine. Then on my s107 I flew into a door and the top rotor had zero spin although the motors worked. In that case the screw that sets the top rotor onto the middle shaft loosened resulting in no lift and also tilted and fell over. This was fixed by securing the set screw properly. So in both instances it was similar effects due to the top rotors not spinning in sync with lower blades.
Jun 03, 2012 | SYMA Toys industrial Syma S032 Ready to...
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
Mar 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
SYMA S107 Helicopter. Advertised as 3 channel. Remote has channel marking of A B C, but the switch is only 2 position. How do you achieve 3 channels with only 2 position switch?
This helicopter have 2 channels I see.
Maybe A-B is first position and B-C is secound position channel. Helicopter have not switch ABC, simply turn off and turn on for change channel.
Jan 14, 2011 | SYMA Toys industrial New Syma S107 Mini...
I can't seem to charge my S107 helicopter. I plug the USB charging cable into my computer, and then the helicopter itself, but have no indication that it is charging. Should I see a light on the...
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
Jan 01, 2011 | SYMA Toys industrial New Syma S107 Radio...
My Syma S107 will not lift off the ground. what can i do to sort this out?
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
260 people viewed this question
Top SYMA Toys industrial Toys Experts
Kjetil Balstad
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
