Question about Health & Beauty
Hi. my omegatrac is having what seems to be an electrical issue. it won't fully charge and we have tried two chargers. also, if i try to drive up even the slightest grade it shuts down and blinks. i also hear a click from the area around the charger connection point on the main power board.
  • nathan_bolto Dec 29, 2010
    yeah i have..if new batteries doesn't fix it trust me i'll be back on here asking your help. thanks
Sounds like the batteries, check voltages, both should be very close in voltage and higher than 12.5 volts
Posted on Dec 29, 2010
  • 5 more comments
    it actually drives fine while connected to the charger..obviously i can't go far :). thanks
  • dandoe288 Dec 29, 2010
    Have you had the chair long? I have 3 of them, I got them all used in the last year. If there is something I can help with.. i'm here...
    cheers,
    dan
  • mrrhbjr
    mrrhbjr Jan 14, 2013
    dandoe,
  • mrrhbjr
    dandoe, my omegatrac motor is burnt. The motor just needs one new brush spring.
  • mrrhbjr
    If one of your motors is burnt, I could use parts from it.
  • dan9919
    dan9919 Jan 14, 2013
    I just changed out the drive motor and it sits on the floor. Where do you live?
  • Benjamin Hernandez Feb 24, 2013
    I will buy any brushes if they fit my Omega Trac,
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
When the "Philips Senso Touch 2D" electric shaver is fully charged should the charger be turned off
It is not advised that you leave the shaver charging after it has fully charged.
Apr 17, 2013 | Health & Beauty
My phone won't connect to WU1a...
Try putting your phone on the charger this is a problem I've had with my phone connecting to WIFI it seems to take more battery power to make it act right make sure it is fully charged.
Jan 28, 2013 | Cameras
Victory 4 pride mobilty scooter,the charger dont seem to charge up the batterys. is the charger faulty.
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
CLICK HERE MANUAL
Aug 27, 2012 | Pride Go Go Ultra 4 Wheel Travel Scooter
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
My laptop won't turn on, even I try to plug the charger it won't charge. and the light indicator if it's charging is not on. The problem start when I using it while charging and it's...
Remove the battery and check the voltage on the battery, if low try to JUMP charge, if not replace. Also check the charging voltage with the adaptor connected to the latptop. If there is no voltage then the charger must be checked.
However if the battery and adapter seems good then the mother board is a suspect and it is ideal to get the help of Tosibha service for estimation.
Jun 25, 2011 | Toshiba Satellite L500 Series Notebook
The charger of Dsc-t5 is blinking
The supplied charger normally lights while charging and turn off when the battery is fully charged. If the battery charger is blinking, then issue may be with the battery not getting charged. I suggest that you try using a different battery and check if the issue is with the battery.
Thanks for using FixYa.
May 12, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
My scooter says its fully chrged but its not. this happens once in awhile, any suggestions?
your batters have lost their charge at some point in time. These gel batteries, if they ever set for a long time with out recharging, or arn't recharged daily with daily use, will seem to be charged. but arn't. their expensive but I've seen batteries last over 5 yrs when taken care of properly.
Nov 09, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
