Question about Brother Sewing Machines
Hello, I know my question is irrelevant but please help!!! I have a brother kh-970, I've tried to create a lace pattern, entered into machine, entered memo for it but when in positioning program tried to select a Lace carriage it gives me error 13-the pattern is not a lace pattern. Tried to enter a pattern from manual instractoin book with its memo it sent me same message again. Please, could any one help please???
bargainbox
  • 1388 Answers
SOURCE: I have a brother machine
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 24, 2008
  • 5 Answers
SOURCE: I purchased a 750D Brother
HI, When your pattern comes up on the visual screen the pattern is broken into different color components. If you touch the pattern on the screen it will delete the component you hit, which will in turn bring you to next component if not the first, which will cause you to start in the same place sewing the same area over. do not touch the screen just change the thread after each component
Posted on Oct 27, 2008
RickE1
  • 202 Answers
SOURCE: Timing is off on my Pfaff 2140/2170 machine.
Basically on any sewing machine to time it you will need to separate the two gears that drive the hook. Usually loosen the set screws that attach the gear to the shaft and separate them.
Time the hook first. On center needle position, set the hook so that the point is behind the needle when the needle bar has risen about 2.5mm.
2) Set the needle bar height. Choose the needle position which is the last for the hook to pass.
(Left on most machines, right on older Vikings) At this point, place the point of the hook behind
the needle and set the needle bar height so that top of the eye is just barely below the tip of the
hook.
3) Check feed timing. Set the stitch length to the longest stitch. The needle should enter the
fabric just as the teeth drop below the surface of the plate.
Posted on Dec 20, 2008
SOURCE: Brother mechanical sewing machine XL-5060 - Can't select stiches
I have been provided with the solution by Brother.
If I turn the Stitch Length dial to "SS" I can select stitches from 10 onwards.
Wish they could have put that in the manual!.
Posted on Jan 19, 2009
SOURCE: My Brother KH-270 knitting machine
What you do is load the yarn into the carriage and draw it accross the bed of chosen needles once.
After that hang on the cast on comb on these loops that are formed and put on some weights, and then start knitting. Push the carriage back & forth forming stitches. It will then form stitches and when removed from machine won't run. Read you manual, it explains all this.
Thanks for asking.
Posted on Mar 16, 2009
Instructions for use of a brother knitting machine kh-860
Try Googling (brother)(kh-860)(manual) without parens.
Apr 28, 2017 | Brother Sewing Machines
Finding knitting patterns for fine lace knitted dresses for ladies
There are many Lace Dresses available in the market or in the online stores. If you want to select knitting patterns for fine lace knitted dress than you should definitely try this online boutique and that is lily boutique.
You may find many varieties and designs according to your choice. You can also select another pattern as like navy colour dresses and many more parties wear dresses.
Feb 25, 2017 | Sewing Machines
I need to rotate my pattern by 45 degrees on my brother pe 770. I've tried going to layout but it only does 180. Any ideas?
Get software such as Embird Design to do it and then export the .PES file and transfer to the machine. Unfortunately the low end machines do not have this capability.
Apr 02, 2013 | Brother PE770 Computerized Sewing Machine
Error Message This embroidery card cannot be used with this machine
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Feb 16, 2012 | Brother SE-270D Computerized Sewing...
I have a Brother KH970 Knitting machine from a customer that has a problem in the timing. It doesn't select needles. I need instructions on the timing of the machine. I have manuals for older machines, but...
I have a parts manual & a service manual saved on my pc for the 970 that I can send you when I get home in a couple of weeks. Would that help? It gives the information to do tests etc.
I am also on the Yahoo MK site. That may be a better place to share as I am not sure about this site.
-Janet
Apr 03, 2009 | Brother Sewing Machines
Brother knit Eldorado model 35 or KH 35 Manual?
i have the manual for the KH 35; and i would be willing to make copies. my machine needs a needle bed. it will not run as-is.
it would be helpful to know which machine(s) is most worth 'saving'. the manual would help to run a thorough check, as i've just done.
l propose that we compare the condition/needs of our machines. hopefully, one of us would be willing/able to provide the other with replacement parts.
Nov 11, 2008 | Sewing Machines
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
