Question about Samsung CLP 300 Laser Printer
In spite of changing the black toner cartridge and toner waste receptacle, the printing remains faint
    President:
  • 670 Answers
If your printer prints with faint vertical stripes like this
In spite of changing the - slamfix_22.jpg The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Posted on Jan 07, 2011
Kyocera EP470DN - Has Toner - Won't Print
MHHH, it seems as if its empty but it might be that it has humidified. Take out the toner and shake it side ways without compassion, then you slow down and shake it gently a couple of times then install it at the drum. You can also verify if this is true if you take out the toner and watch the roller and see if its loaded with toner. If it looks shinny with almost no toner it what I just exposed. Luck
May 10, 2013 | Kyocera Mita EP-470DN Toner Black EPT-470
Faint grey printing
According to the service manual for problems with light print image, the cause can be the Developers or High Voltage Power Supply (HVPS). Other possible causes are given as: Developer roller is stained when the toner or developer cartridge is almost consumed. Ambient temperature is below 10 degrees Centigrade. Bad contacts with the HVPS or abnormal output from the HVPS. To replace the Developers you would need to purchase a replacement Imaging Kit CLP-R300A. Any problems in the HVPS would require a factory repair.
Dec 13, 2011 | Samsung CLP 300 Laser Printer
The print on the left side of the page is faint. I have an HP LaserJet 3030. I used the printer's cleaning system, but the problem remains. Any idea how to fix this problem? Thanks
First make sure that the cartridges are OK and have enough toner. (Remove the cartridges and inspect it physically, shake it horizontally so that the toner inside the cartridge is evenly distributed) If it happens even if the cartridge has enough toner or after replacing the toner cartridge, it is most likely be due to dust accumulation at the laser reflecting mirrors inside the printers, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 04, 2011 | Office Equipment & Supplies
Getting a black stripe on the right side of print
Black stripe is the main problem of damage roller drum inside the toner cartridge or damage fuser film drum inside the printer. Check first the roller drum of toner cartridge if both sides of the roller is tear off. That would be the problem. If not the fuser film inside printer is damage. This is dammage due to continues bulky printing.
But if your refilling the toner cartridge, you need to clean the waste bin compartment of the toner cartridge maybe it is full and waste are overflowing on it making black stripes on your printer and will damage both printer and cartridge.
Dec 09, 2010 | Brother HL4040CN Laser Printer
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
Feb 25, 2010 | OKI C5250n Printer
How do i check when toner cartriged need changing
When the print on the paper is faint and not as black as normal.
You can get a few extra prints from the toner cartridge by removing the toner cartridge by giving it a shake in the horizontal position and inserting it back into the printer.
Jan 15, 2010 | Canon Office Equipment & Supplies
1" stripe on rt side of page
First you make sure is not the toner cartridge causing the problem.
if toner cartridge was replaced and problems remain the same....
then you have a bad "FUSER ASSY"
Not very asy to replace by the regular USER....Need to take to a printer repair shop.
Jul 30, 2009 | HP LaserJet 3030 All-In-One Printer
Printer is printing entire page black
  1. clean the cartridge properly.
  2. take the waste toner from waste section
  3. change drum
  4. change chip
  5. do it this i think your probalem is solved
new problem
  • changed black cartridge but print color mixed print out
what i do? send the details to my email
May 14, 2008 | HP Color LaserJet 2600n Printer
Samsung CLP 300 Laser Printer Logo
145 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
