Question about Hitachi 61UWX10B 61" Rear Projection Television
The convergence is off on my Hitachi 61UWX10B rear projection TV. I was unabel to fix it using the remote
  • 53 Answers
The chips and 12 resistors need to be replaced, below is a link where you can find them. I've done business with them. They're very reasonable and give you step by step instructions to fix it yourself.
http://www.tvrepairkits.com/xcart/product.php?productid=20080&cat=1647&page=1
Posted on Dec 28, 2010
Hitachi 61UWX10B 61 in. Rear Projection Television, See double image, Magic focus doesn't fix
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Hitachi 61UWX10B 61" Rear Projection...
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
Jan 16, 2010 | Hitachi 61UWX10B 61" Rear Projection...
OK I HAD A GUY COME OUT TO FIX MY TV THE COLORS WERE NOT MATCHING UP?SO HE TOOK SOME BOARD OUT AND PUT SOME NEW PARTS!STILL DIDNT WORK??SO HE GOT INTO SOME MAIN SETTINGS AND MADE MY TV INTO A 42''NOW AND...
Colors 3D like?Ur convergence it dead.Must replaced the convergence ICS all it resistors to solved this porblems.If same problems,than he did put in functional board.
Dec 13, 2009 | Hitachi 61UWX10B 61" Rear Projection...
The colors are not aligning correctly. I have tried to use the magic focus but it still did not align.
You have a convergence problem. Go into the menu and you should find a convergence alignment menu, try to align it there, if you can`t then you probably need local help from a tv repairman. good luck
Nov 17, 2009 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61uwx10b needs more convergance work than magic focus can apply. Options for savvy DIY'er ?
Know basic soldering?That all require changing convergence ICS all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.
Oct 02, 2009 | Hitachi 61UWX10B 61" Rear Projection...
My color doesn't line up on my hitachi 61UWX10B somebody said color mod is bad
Replace the convergence ICs you need two STK392-110 convergence ICs You can get replacement ICs at the folowing link with free isntallation instructions.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | Hitachi 61UWX10B 61" Rear Projection...
Convergence
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
replace both convergence ic's
Nov 12, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Convergence Problem
replace convergence ic
Oct 16, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi Projection 61UWX10B
Does your set have Magic Focus, if so then you can adjust manually. And when Convergence is acceptable, press Move to write data to ROM memory. Rom Write? is displayed to alarm system that ROM will be over written with new data, Press the Move button again to write displayed data to ROM. Data Write will take 20 sec. aand no picture will be displayed Green dot will be displayed when operation is complete. Press Mute to returen to converg. pattern, then confirm again converg. is acceptable. Press MOVE(ROM WRITE) mode, then press PIP ch to initialize sensor dat positions.
Dec 11, 2006 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 61UWX10B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
