Question about Mitsubishi MSZ-A15NA Split System Air Conditioner
Mr. slim MSZ-GE15NA indoor unit was working fine. Now when i turn it on it runs for 5 minutes then the operation indicator light goes from full on to blinking and the units turns off. the outside condensor never comes on.
  • chuck136 Dec 30, 2010
    i'm not sure what was going on - i turned the power supply off (220v) and left off for about 5 minutes then reset thermostat. unit came back on and has been running fine since. i checked the blinking light - it ws blinking constant about every 1/2 sec. the manual suggested possible wiring issue - i checked the wiring on the inside and outside unit and the power at the outside disconnect. everything checked out fine. hope this was just a fluke. thanks for your response.
  • Mitsubishi Master
  • 43,501 Answers
There is either a problem with the outdoor unit fan or compressor or there is a communication problem between the two....
Did you check the number of blinks and then check the book to see what it means??...
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Dec 29, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Dec 30, 2010
    You may have had a power glitch... either high or low voltage that messed with the unit... turning it off and then on reset everything again....
    You will likely be okay again...:-)
Wall unit keeps frosting up, will not heat
Clogged air filter or a loose belt between the fan motor and fan wheel will cause a frost up.
Nov 19, 2015 | Mitsubishi MSZ-GE15NA Mr. Slim Wall...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
How do I clean Mr Slim MSZ 24NA
usa.mylinkdrive.com/.../MSZ-MSY-A09-24NA_GA24NA_Service_OB
Sep 19, 2014 | Mitsubishi MSZ-GE24NA Mr. Slim Wall...
Msz a12na unitHOW DO I TURN HEAT ON? it worked fine last winter...? now the icon doesn't come up on any of the 3 units i have in the house.
Clean filters. disconnect from power for 10 minutes Reconnect and replace flitrs restart units. Set to heat on high.
Nov 09, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim indoor fan shuts off
Might change the battery on your control. I wish these had a hard wire thermostat not a big fan of the remote can be confusing.
Mar 19, 2013 | LG LS-L1210CL Mini Split Air Conditioner
I have a Mitsubishi Mr. Slim Model MSZ-A09NA. We just purchased the house and have only been using it for a week. I had it serviced on Friday and was told it worked fine. Sat. we had a power outage. ...
Hi, it sounds like you may have lost the blower motor due to the power surge. Normally, it would kick the breaker off.The code is just telling you something is not right as you know. You can try turning off the breaker to the indoor unit for 10 minutes or so, and reset it to see if the blower will start. If you have the manual, that might tell you what the code or light is. Its more then likely a 220 volt indoor unit. Sometimes on a double pole breaker, only one half of it will trip in a power surge. Check to see if this is the case, as you may only be getting 120 volts to run the vanes. If its half way tripped, turn it off hard, and back on hard. that may be your problem. If not, call the service tech, and just tell him it stopped working. He will come out at know charge to you. I bet its your breaker though. Please let me know.
Sincerely,
Shastalaker7
A/C Contractor
Jun 06, 2011 | Mitsubishi MS09TW Air Conditioner
We have a msz-ga80va split cycle, indoor unit runs for about 5 minutes without cooling then cuts out, outside unit doesn't kick in at all
Just had the same thing happen to us with the same model (right on Xmas day).
Checked the circuit breaker is on in the fuse box. Power is on to the external unit. Filters are clean.
Internal unit activates... both indicator lights on. After 5 minutes blowing air it stops and the right indicator light goes out and the left indicator light blinks constantly.
The troubleshooting guide inside the internal unit (under the outer cover you open to clean the filters) suggests that 14 blinks is an abnormality with the external unit and refer to service manual.
Think we'll be calling a technician.
Dec 26, 2010 | Mitsubishi Heating & Cooling
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
May 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MSZ-A15NA Split System Air Conditioner Logo
475 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
