Question about Apple iPhone4 4G iPhone 4
All of a sudden itunes will not recognize my iphone when I open it up. When can I do to fix problem? I have uninstalled and install itunes twice.
Hello. Did you take a look at the genreal setting of the iTunes?? You can configure if you want itunes to be loaded automatically whenever you plug you iPhone
Posted on Mar 01, 2011
Why does an error message continue to pop up when I am trying to restore my iPhone?
Since you didn't mention the error code number, I am going to assume it is 3014 because it is the most common iphone error associated with restoring the iphone. A fix which have been confirmed to work in most cases can be found here:
Fix iPhone Error 3014 iTunes Error 3014 During iPhone Restore
Sep 24, 2014 | Apple iPhone 5S
My Iphone won't recognize in my itunes? I tried restoring all the USBs but it still won't work. It charges and everything in the computer just won't recognize? Anyone know anything?
Hello, I'm going to try to work this issue with you.
If you had tried all the usb ports, different cables and drivers are installed, then we need to work with iTunes itself. Usually iTunes is more of a headache in Windows than in Mac.
First off, make sure that you have the latest version of iTune, if you have the latest version, then you could try a clean install. Meaning that you need to uninstall iTunes, remove all logs about iTune, reboot, and re-install iTune. Let me know if this works for you.
Mar 24, 2014 | Apple iPhone 4S
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | Apple iPhone 3G
Itunes or windows wont recognize iphone 3g
uninstall itunes and the other components such as quicktime, apple mobile device support, apple application support,apple software update and bonjour.
  • go to your control panel and add or remove programs(win vista or 7) or programs and features(win XP)
  • remove the stated programs from above, restart your computer
  • visit apple.com/itunes and download iTunes and install.
  • plug your iPhone in and then it will load the driver for it and then be recognized again by your itunes and computer
Dec 15, 2010 | Apple iPhone 3G
How to solve if my iphone 3G cannot be on, it stuck at the apple screen?
  • The quickest way to fix your iPhone 3G is to sync it to a different computer. When you do this the computer will recognize it as a new device and install the software on it like it's never been used before, that said everything you have on it is gone. It may take a while so be patient.
  • 2 If step one is successful you can sync it to your computer. It will recognize that it is synced with another computer and ask you if you want to sync it to this one; go ahead and do it. This may take a while too because you will install the applications, songs, data, etc. you had on it before.
    WARNING! DO NOT DISCONNECT YOUR IPHONE 3G WHILE SYNC IS IN PROGRESS OR ELSE YOU WILL BE STUCK IN RESTORE MODE AGAIN!
  • 3 If steps 1 and 2 did not work or you do not have another computer to sync it with the following steps will help.
  • 4 Backup your music, videos, and applications. Typically it would be the iTunes folder in the My Music folder. This is a precautionary step to the following steps to come, your music should be unaffected but stranger things have happened.
  • 5 Uninstall iTunes, Quicktime, and other Apple component software from your computer. Follow the steps listed on the Apple Support page, "Removing iTunes, QuickTime, and other software components for Windows XP" the link is available in the resources section. Restart your computer when done.
  • 6 To be sure everything is uninstalled completely run the Windows Installer CleanUp Utility. This program removes remnants of uninstalled programs from your registry and deletes files that the uninstall fail to catch. You can download and read more about this program from the Microsoft Help and Support Page, "Description of the Windows Installer CleanUp Utility" the link is available in the resources section. Restart your computer.
  • 7 If you have a registry cleanup utility like Registry Mechanic or CCleaner run the program and restart your computer. It is sad to say but the Windows Installer CleanUp Utility may not catch everything so having a secondary cleaner could be essential.
  • 8 Install the latest version of iTunes. Currently iTunes 8 is the latest, it could change tomorrow so download it from Apple.com. Restart your computer.
  • 9 Open iTunes and connect your iPhone 3G. It may take a while for it to recognize the phone, be patient. Once iTunes recognizes your phone it will prompt you to download the latest iPhone software, the current version is 2.1. Follow the installation instructions in the Apple iPhone - Software Update page, the link is available in the resources section.
  • 10 Hopefully these steps helped you recover your iPhone 3G. It is possible that even after a successful recovery your phone may revert back to being stuck. In my experience I was able to save my iPhone 3G from restore mode but when I downloaded the software update it got stuck again, luckily steps 1 and 2 fixed it.
  • Oct 06, 2010 | Apple iPhone 3G
    Hi, i jailbreaked and unlocked my husbands iphone 2g. It was working fine until he try to install native mms, it froze. I don't know what he did but iphone reads sim card but itunes does not recognize it....
    when u jailbreak and use itunes u have to get app sync or u will leave ur iphone frozen in a state that u cant restore no only other way is if u uninstall itunes and then reinstall
    Oct 22, 2009 | Apple iPhone Smartphone
    ITunes doesn't recognize iPhone SIM card
    u pls jailbroke the iphone with redsn0w , then it will be
    Aug 26, 2009 | Apple iPhone 3G Black Smartphone
    Need an expert, I have paid fixya twice but no solution to probl
    get a palm pre when they come out (im a fan of Macs, but not apple's portable devices)
    Mar 26, 2009 | HP Computers & Internet
    My hp doesnt recognize my iphone
    try uninstalling itunes and install it again. I'm sure it will help
    Thanks
    Jan 07, 2009 | Apple iPhone Smartphone
    Iphone
    Reinstall iTunes - quickest way to fix this problem. If this does not work, uninstall iTunes and Quicktime. Reboot. Reinstall iTunes.
    Feb 19, 2008 | Apple iPhone Smartphone
    Apple iPhone4 4G iPhone 4 Logo
    91 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
