Question about Brother MFC-8860DN Printer
Toner end life message
I replaced the toner in the MFC8860DN. It still displays a toner end life message and the machine will not work. I took the drum/toner assemble and placed it in another MFC8860DN and everything works, so the problem is in the original MFC, not in the drum/toner assembly. How do I reset the toner end life message so that the MFC knows it has a new toner in there? I am NOT talking about the drum.
  • 2 more comments
  • pumpkin976 Nov 05, 2008
    I have replaced the toner cartridge also but continue to get the toner end life message. I turned it off and on, unplugged and replugged it.same message
  • umairasmat Nov 17, 2008
    I replaced the toner but it still says "Toner life end"
  • Anonymous Jan 29, 2009
    My refilled toner gives "Toner End Life" message. I used it in another identical MFC-8860DN and worked well. Also, an original toner half way used from the second one which is working gives the same message on the first one. I don't believe there is a problem with the toner cartridge or any gear or spring in it. There is a code in the machine that has to be reset. Other models use clearing code of "*00" after pushing "option" key in the copy section of controll pannel. I can not find this key on MFC-8860DN. HELP?
  • 26boy Jan 29, 2009
    My refilled toner give "Toner End Life" message. I used it in another identical MFC-8860DN and worked well. Also, an original toner half way used from the second one which is working gives the same message on the first one. I don't believe there is a problem with the toner cartridge or any gear or spring in it. There is a code in the machine that has to be reset. Other models use clearing code of "*00" after pushing "option" key in the copy section of controll pannel. I can not find this key on MFC-8860DN. HELP?
    Problem Solver:
  • 14 Answers
I solved the brother mfc8860 toner life end problem
hi guys my name is reedwaan. Im new at this site so please listen up
my brother toner i refilled with toner and inserted it. It said toner life end then i patched the windows close on the sides and still the same problem, then i removed the toner and loosened the two screws on the left by the gears then removed the cover of the gears.
Right at the back there is a funny looking gear with a spring behind it. All you have to do is pull the spring a little bit clockwise and push the gear back on hooking the spring into it so that the gear is spring loaded. close it up then test it, It took me a while to figure it out but i got it right.
NB*  The gear that you push on, is the toner reset gear and when you push it on make sure the teeth dont interlock with the second gear on the left of it. If you have any queries mail me on reedwaan@yahoo.com
glad to help out
Posted on Jan 09, 2009
    Problem Solver:
  • 7 Answers
You can actually just remove the gear and spring. I posted this fix on another Brother printer. The good part of removing the gear and spring is you can print much longer too.
Posted on Apr 27, 2009
2 Suggested Answers
djuksoni
  • 103 Answers
SOURCE: I replaced the toner in the MFC8860DN. I still
-open front cover
-press 'Option' button
-then key *00 on the keypad
-close front cover
hope it helps
Posted on May 10, 2010
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
Toner life
You need to reset your Brother printer to get rid of the message
Mar 26, 2008 | Brother IntelliFax-2820 Laser Fax
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
How to get ride of Toner life end message
You could try resetting the toner cartridge settings. OPen the machines front door where you would replace the cartridges. On the top panel you will see a "clear/back" button. Press it and on the display you will see a reset menu come up. Arrow to each one and hit the OK button. Press "1" to reset. Once you have gone through all close the front door of the machine and press stop to bring the display back to normal.
Hope this helps.
Oct 17, 2009 | Brother MFC-9840CDW Laser Printer
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
4. Press 1,0 .
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner life
where and how to find the reset actuator?
Nov 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-8860DN Printer Logo
1,902 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
