Question about Remington R-650s Electric Shaver
Seems like the battery is not powerful enough to turn the rotary blades fast enough. Not sure a new battery is available and if so not sure it would solve the "speed" problem.
  • Remington Master
  • 1,610 Answers
Slow speed indicates to me that the blades need cleaning. Disassemble the blades completely and clean them. They are probably clogged solid
Posted on Dec 31, 2010
John deere la145 wont turn over
Make sure the blades are turned off. If so, turn them on and off a few times to cycle the switch and see if it starts. If not, you'll have to start from the batteries and go to the fuse and check for power to and through the keyswitch until you find the place power is lost. Do you have a 12 volt test light?
The battery will need to be tested with a volt meter that will tell you how much voltage is available. The fact that it can light up a continuity tester will still have you guessing whether it has enough voltage to operate the starter.
Aug 09, 2016 | John Deere Garden
Won't turn over fast enough to start
Try to Jump start it with the jumper cables and make sure your battery has enough power to turn the Engine....
Jun 07, 2016 | 1994 Ford Mustang
Polan selfpropeled mower the blade is not spinning fast enough and hardly cuts the grass
Blade speed equals engine speed. Check your carburetor and fuel pipe
Make sure you sharpen the blade with - this is more important for a good cut.
Mar 19, 2014 | Garden
88 rx7 run but wont start
The FC3S is notorious for this and fueling issues. Check all ground points, battery cables and connections. Check the draw from the starter. If the voltage drops below 10V there is not enough power for the ignition, causing weak spark. It really needs to spin over 200rpm cranking. Pop starting does not necessarily mean the compression is good. You need to make sure it cranks fast enough to get a proper compression test with rotary tester, New NGK plugs, new NGK plug wires.
May 28, 2012 | 1988 Mazda RX-7
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
Makita 2012nb planer. The drive (top) sprocket keeps stripping out the flats on its arbor hole and the allen bolt loosens and backs out. Not sure which happens first. I've tried high strength loctite...
I think your screw is broken you should change the screw which attach the rollers and the blade. If you start a machine, screw turn out and let the roller stop rolling that means your screw and the ring are broken, you have to change them.
May 08, 2011 | Makita 2012NB Electric Planers
Accord seems to be draining power overnight. only a fast clicking sound when attempting to start. battery 6 months old.
hi, it seems you have a fault DISCHARGE OF BATTERY: make sure there is no lights left ON vehicle inside or out, if phone charger left ON the fast clicking is the starter motor solinoid triing to connect to the starter motor NOT ENOUGH CURRENT TO START ENGINE, sometimes the alternator can have a slight fault, water driping on the contacts on the alternator will flatten the battery, (this is a DIRECT CONNECTION TO THE STARTER MOTOR and BATTERY). naturally the clock, radio, alarm system, all these sytem reduce the battery but this is NOT THE FAULT. charge the battery again it may be just this once. gerry
Sep 08, 2010 | Honda Accord Cars & Trucks
I have an MKM6003 grinder, the blades are not moving fast enough
I had the same problem and had disassembled the complete machine. I found many videos on youtube how to take off the blades, but all solutions does not work. The motor does not turn when I turn the blades. The blades are screwed, but as long as the motor does not turn I can't disassembly the blades. After nearly two hours I was so frustrated that I take it off with brutally power and then I saw the problem: The thread (german: Gewinde) was made of plastic and was destroyed by the thread of the metal axis of the motor. The axis was wrapped with parts of the plastic thread. So, if you're not worry to disassembly this device you have to buy a new blade: http://www.bosch-home.com/de/store/product/Messer/00176106. Copy and paste the material number to search for that part in your country.
Jul 20, 2010 | Bosch MKM 6003 Electric Blades Grinder
My diesel engine on my VW TDI Jetta is having a hard time turning over. It takes forever to start and seems to be getting worse.
Have someone replace your fuel filters ($$$) and put a bottle of "Lucas Diesel Additive" available at Advance Auto Parts $8
P.S. If you have PREMIUM Diesel available in your area (BP-Chevron) run that for a couple of tanks.
Good Luck
Jun 15, 2009 | 2002 Volkswagen Jetta TDI
Remington R-650s Electric Shaver Logo
127 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
