Question about Dell Inspiron 9400 Notebook
I have a Dell Inspiron 9400. I have took it apart and removed the motherboard so that I may replace the dc adapter with a new one. Can any one tell me how to do this the correct way without causing damage to the motherboard? I was told it may have to be soldered.
  • Dell Master
  • 4,338 Answers
Yes, the DC connector has to be soldered. The original one is probably still good. It just came loose from the laptop. Here is how to resolder it:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Posted on Dec 28, 2010
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
Dell inspiron 9400 not booting up. no light in display. num keys and caps locks flashing
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jan 28, 2011 | Dell Inspiron 9400 Notebook
My Dell inspiron 9400 wont charged my battery. Both the charger and battery are new
try to charge the battery while the computer is off for 3 hours. if that does not work, remove the battery from the computer and turn on the computer using only the ac adapter. if the computer is working fine using only the ac adapter, call your computer manufacturer for possible battery replacement
Jun 11, 2010 | Dell Inspiron 9400 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
I bought a inspiron 9400 off ebay and the bios is locked. Dell will not help me because I am not the original purchaser. please any help.
Only A Couple Things You Can Try Here.....
You Can Attempt To Clear the BIOS By Removing The CMOS Battery...
You will have to disassemble to get to it...Not sure offhand on your exact model whether your battery is plugged into the motherboard or directly soldered.. I am almost certain yours is a Snap in/out that gets inserted into a carriage on your motherboard... Either Way... You Will Need to remove it... Make sure your Power Battery is also removed... and your AC Adapter is not plugged in..
Then Press and Hold Your Power On Button To SHort Out The Connection... THen After 30 seconds or so.... Reinsert CMOS Battery...
Reinsert Power Battery...Plug In AC Adapter...
Attempt To Power On
Didn't Work... Option 2:
Try Using A Backdoor Password Or Default Pass...Go To THe Following Link For More Info On It: http://www.tech-faq.com/reset-bios-password.shtml
Still Didn't Work... Option 3:
The BIOS Will Either Need To Be Flashed... Or You Will Need To Replace The Motherboard...
The BIOS ROM CHIP can be flashed (erased and written over) but it is costly... you Can Google Search That Information If You Choose To...
Use Search Term: Dell Inspiron Bios Flash
Dec 08, 2009 | Dell Inspiron 9400 Notebook
Dell inspririon 9400 wont start
(before you do anything remove the battery and th ac plug)remove the memory inside small door on the backside that has a "M" on it now once you remove the memory install the battery, power on if you hear a couple of beep tones you are half way there the motherboard is good so the problem is what you took out so there are two memory slot try them in the A slot one at a time.If the problem is memory replace it.
Good luck
Aug 29, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Dell 9400 Won't Start
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
Nov 18, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
46 people viewed this question
Alun Cox
